This thread may be safe for LBA after you see my examples.
I have had my Sigma 28-300mm 3.5-6.3 DG for nearly three weeks now and some of you may be interested in my vulgar use of the English language fit into some review of sorts. Here goes:
My K10 has some issues helping it to find the focus point and locking it. It seems to be a little better on my K-7. I have been getting use to focusing manually not because of necessity but out of habit since I use MF lenses more and more.
It is a good thing the lens is an automatic aperture because there is very little room between the flash shroud, zoom ring and the aperture ring. It takes some finger manuevering to depress the A switch if you wanted to manual move the aperture ring out of the A setting. The clearance is a little greater on the K-7 than the K10 but still, very little space for a finger.
It often does not focus fast. Performs very much the way my Pentax DA 50-200 does with regards to the speed at which it moves to find the focus. But the DA will hunt a little more, moving in an out of focus until it is locked. Both lenses have a tendency to make very small movements to lock the focus but for the most part, the Sigma lens is better at locking on focus compared with my Pentax DA 50-200mm.
The color and contrast are pretty good. Very close to the image quality of many of Pentax's lenses. And it seems sharp enough. There are times when it seems that there is a fine line between sharp focus and not sharp focus. When I am manually focusing, it seems that you either get it focused sharply or you have missed. The focus ring seems that intolerant to small movements. Turning the ring in the slightest gets you images that are clearly out of focus.
I like the compact size for it's somewhat wide focal range. My K10 underexposes in shaded areas with this lens more so than perhaps other lenses. But EV compensation or manual adjustments take care of that.
I don't yet know if it's performance overall is as satisfying as my other Sigma lens, the Sigma 24-60mm DG but I think I do like it more than my Pentax DA 50-200.
Now, too many images taken with the lens over the past several days. These are all unedited. Some have slight in camera adjustments and all have been compressed using Picasa. (And I am trying to become proficient with the new flickr. Humor me.)
