Originally posted by lapeen
Also.. while I have your ears... err... eyes... Is it me or is the flash on the k100d REALLY BRIGHT!? (and because of the spaces it comes back at ya and nearly blinds ya!) My fuji's flash was not nearly as harsh as this one is. I will definitely have to buy a diffuser or something.
If you're talking about using it with the M lens, the flash can't automatically adjust output.
The flash can do that when it has certain information from the lens. It needs to know what aperture will be used so it can figure out at what point to cut off the light output to make exposure just right.
The more modern FA / DA / A / etc series lenses have the necessary electrical contacts to communicate with the camera body and give the exposure calculating computer the information it needs.
Older lenses such as the M / K / Takumar series of lenses are unable to communicate like that.
With those, the flash just fires full power and it is up to the photographer to calculate and set the appropriate aperture to adjust exposure.
You'll have the same issue even with flashes other than the built-in one. If the flash doesn't support P-TTL (and very few do) or doesn't have the word "auto" in its name somewhere, you'll have to do the calculations yourself....and the setting the aperture caveat regarding older lenses still applies even with a P-TTL capable flash (The P-TTL won't work to regulate the flash output).
If you're considering buying a hotshoe flash unit, please be sure to read up on relevant threads or start a new one because it is very easy to end up with something that could potentially damage your camera.
