08-13-2010, 08:55 PM   #1
Something has gone wrong with the 77!
Was cleaning it for a photo shoot. With it on body, grasping focus ring, and pulling in and out there is probably 1mm of movement (not the front of lens). There never was movement between the focus ring and rear of lens before. Checked the screws that hold the bayonet mount to the lens - all are tight. Any ideas? Guess its going in for tlc.
thanks
barondla
Check out POINT & SHOOT CONTEST #32 in compact camera forum. Enter #33. Any brand camera. Enter now!
08-13-2010, 09:41 PM   #2
wlachan's Avatar
Sounds like the 3 screws holding the focus ring in place are loose. This also means the focus has probably shifted already. This is not uncommon with modern Pentax primes because they weren't tightened and thread-locked sufficiently in the factory. If you managed to unscrew the metal retaining ring off the filter thread, you may remove the filter rim too then you will have full access to these screws. Just reset the infinity focus and tighten them, then it will be good as new. You may also reapply the thread-lock to the threads so that they will not loose again.
08-14-2010, 06:11 AM   #3
The filter ring is different than most I have seen. The little detents the spanner tool goes in are semi covered by a ring. Removing the ring to reach the three screws seems possible. Do the lens elements stay in the lens?
thanks
barondla
08-14-2010, 09:25 AM   #4
wlachan's Avatar
By removing the retaining ring and the filter rim, nothing else will come off including the glasses. The little detents for the wrench belongs to the whole front element group. You don't need to touch that at all.
camera, focus, k-mount, lens, movement, pentax lens, slr lens
Am I doing something wrong...? imwillb Pentax DSLR Discussion 3 12-10-2009 11:49 AM
Was I doing anything wrong? jct us101 General Talk 10 09-14-2009 08:01 PM
Sometimes wrong is right Mark2100 General Talk 5 02-07-2009 09:19 PM
what have I done wrong here? johngs Post Your Photos! 12 01-28-2009 01:58 AM
What's right and what's wrong? dws1117 Photo Critique 2 01-08-2008 09:13 PM
All times are GMT -7. The time now is 06:38 PM. | See also: NikonForums.com, part of our network of photo forums!
