08-17-2010, 12:00 PM   #16
georgweb's Avatar
QuoteOriginally posted by yeatzee Quote
I want a longer hood than what was originally made for a 50mm. Like wheatfield said, in reality I want an 85mm hood.
Well, you can always do it yourself.
One last thing, afaik the diameter of slip-on hoods is being given as per the outer diameter. So, for a 52mm thread lens it'd be something like a 54mm slip-on hood.
Good luck,
Georg
08-17-2010, 12:18 PM   #17
QuoteOriginally posted by georgweb Quote
One more thing,
you could try to get the filter thread in shape just so a step ring could be kind of forced into it. Let's say you are putting a 52>55mm stepring onto your lens and let it stay there permanently. Got to do it with the stepring attached to something more solid, which you can grab (e.g. a hood).
Be careful,
Georg
This is exactly what I did with my dented Cosina 55mm f/1.2.
The threaded filter ring was dented and the threads were somewhat flattened. I used needlenose pliers -- with several layers of masking tape around each tip at the working end to soften them up and avoid further metal-on-metal thread damage, and slowly, patiently worked it back to almost-round.
Then I carefully screwed a step-up ring on there, very cautiously, because some of the threads remained pretty thrashed and there was potential for cross-threading. It took a while, slowly working it back and forth, to get the ring to go on straight. (I think it was a gradual process of straightening the bent threads back to fit the mating section of the step-up ring).
Now that it's on, I'm never taking it off! I use a hood that screws onto the undamaged outer threads of the step-up ring.
Good as new! Well, almost, and I got the damaged lens at a great price so it was well worth the effort.
This worked well for me, but of course, no guarantees for your situation.
08-17-2010, 02:16 PM   #18
I know you shoot film, so this differs a bit. I want a longer hood than what was originally made for a 50mm. Like wheatfield said, in reality I want an 85mm hood.
Makes sense. I do the same with my A 50 on my digital. OTOH, a 50mm hood is a whole lot better than nothing. I'd go for that if easily available and then watch for the 85 hood. (If you have a 50 hood, you're justified in going for a K 35/2.0 to use with it.)
08-18-2010, 07:36 AM   #19
macTak's Avatar
I had the same exact situation as you did. I ended up getting the Nikon HS-4 hood, which I'm very happy with. Nice quality and holds onto the lens quite well. It's meant for the 105mm lens among others, but I have not noticed any vignetting with it on digital (keep in mind I and many others use the 135mm Takumar hood for our 50mm Pentax lenses with 49mm threads). Given a couple of weeks, you should be able to pick one up on Ebay for $10 or under shipped. There are also some slightly shallower hoods in the range if you want (HS-8, for 105mm but shallower, and HS-10, meant for the 85mm).
50mm, 50mm f/1.2 lens, clip, f/1.2, hood, k-mount, lens, pentax, pentax k 50mm, pentax lens, slr lens
For Sale - Sold: Pentax-M 50mm f1.4 (with B+W rubber lens hood and Hoya UV filter) (CONUS) s4int Sold Items 5 05-31-2010 08:59 AM
For Sale - Sold: Pentax SMC FA 50mm f1.4 with Lens hood (Worldwide) pentaman Sold Items 4 05-21-2010 08:35 PM
For Sale - Sold: Pentax A 50mm f/2.8 1:2 Macro with metal lens hood hinman Sold Items 4 10-16-2008 07:51 PM
Lens hood for a Pentax FA 50mm 1.4? pcfranchina Pentax DSLR Discussion 3 06-11-2008 06:08 AM
All times are GMT -7. The time now is 07:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
