11-20-2011, 03:08 PM   #16
I echo those that recommend either of the 17-x versions. Unless you know otherwise, 28 mm is just not wide enough (the work around being two photos and stitch). I like my 17-70 (I have DA 17-70) and use the full range, so 17-70 would be my recommendation. But if you are okay with the cropping of the 17-50, then that may be best. The 17-50 has had some reports of front/back focus, so I would make sure the lens is okay before you leave. Can you adjust lens focus on your camera? Thanks. Glenn
f/2.8, greece, k-mount, lens, light, pentax lens, sigma, slr lens, tamron, trip
Pentax FA* 28-70mm/2.8 VS Tamron 28-75mm/2.8 at 50mm pcarfan Pentax SLR Lens Discussion 27 05-30-2010 06:14 AM
Tamron 28-75mm f2.8 or Sigma 24-70mm f2.8? bfo Pentax SLR Lens Discussion 15 05-01-2010 03:47 AM
lens comparison- fa50mm / tamron 17-50mm / tamron 28-75mm bimjo Pentax SLR Lens Discussion 11 03-16-2010 01:10 AM
Wanted - Acquired: sigma 17-70mm or tamron 28-75mm f/2.8 kjfaust Sold Items 1 01-26-2010 07:25 PM
All times are GMT -7. The time now is 01:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
