Originally posted by civiletti An enlarger lens on bellows is not a bad idea if you don't mind manual stop down. I use a Nikor 105mm on helicoid entension tube with Pentax 6x7 and get great results. A 50mm enlarger lens would be good for APS digital.
A short (<80mm) enlarger lens on bellows on an APS-C camera is good for macro ONLY, ie a bellows usually has a minimum thickness such that a short lens can't reach infinity focus. I prefer enlarger glass in the 100-150mm range, long enough for a good working distance for macro shots, also long enough to be used for general photography.
With a bellows and the right adapter rings, almost ANY lens can be used for macros. That's one way to recycle one's otherwise unusable glass, eh?
For a totally weird experience, macro or not, try a Schneider Betavaron fixed-focus enlarger zoom. Originally several thousand bucks, they're now available for well under US$100. Like many enlarger lenses it has an M39 mount, so cheap M39-M42 and flanged M42-PK adapters are needed. I put it on about 30mm extension for general use, or a bellows for macros. The optics are brutally sharp. Using it for non-macro work is disconcerting, since zooming changes both the focus point and the framed area, resulting in a bit of dancing around for the hapless photographer. It is heavy (820g) and the numbers on it are meaningless outside a printing studio. Sure is fun, though!
