Originally posted by DblArrow When you say only modern Pentax lenses - does this imply only made by Pentax! Cause as I was playing with the adjustments it did seem to move the focus point. But could still be in the operator error catagory.
Thanks for your information.
The issue is the camera needs to know which lens is attached to apply the appropriate correction.
In the K20D you can apply a global correction (Apply All) or up to 20 lens specific ones (Apply One)
'Apply All' would apply the same adjustment to any and every lens attached to the body. In this instance the camera would not need to 'know' anything about the lens.
'Apply One' enables you to make different adjustments for different lenses which the camera stores in an internal database. The camera identifies each lens as it is fitted, and if it is recorded in the database it applies the stored AF settings.
As far as I am aware, and I'm happy to be corrected on this, the only lenses that the body knows about are Pentax ones.
