08-25-2010, 07:34 AM   #1
trublubiker's Avatar
DA 15mm LTD and GND Filters
Hi
Has anyone found a way to use a GND filter on the DA 15 Ltd without vignetting ?
I was told by another member that the adapter ring on the extra wide Cokin P series causes vignetting.
Does the Cokin Z Pro have the same problem.
Any help or suggestions appreciated.
PS: I did try a search but didn't come up with a definitive answer.
08-25-2010, 07:48 AM   #2
pcarfan's Avatar
I was able to use my cokin system with the 15. I'll confirm the size etc., later this evening.
08-25-2010, 11:43 AM   #3
luck1's Avatar
I red some talk on dpreview forum about that in the past I did it. square filter holder on beloved 15 limited.: Pentax SLR Talk Forum: Digital Photography Review. But I am sure there will be more try a search
08-26-2010, 02:35 AM   #4
Thanks pcarfan.
And thank you luck1 for the link. It led me to another poster who seems to have a solution.
I know there is a tidy workaround, just got to find it.
Cheers
08-26-2010, 07:57 PM   #5
goddo31's Avatar
I have used the Cokin P series 49mm adapter, along with a 49mm slim profile C-PL filter and don't remember seeing any vignetting with the DA15. I used the polarising filter as a spacer in order to fit the Cokin filter holder over the built in lens hood.
I have however only tried this once or twice, as I didn't like using the Cokin system Technically it's possible there was some minor vignetting, but I certainly don't remember seeing anything noticeable at all.
The reason I didn't like using the Cokin system was due to the fiddly nature of setting it up and that stacking a few different GNDs gave a rather nasty red cast. The red cast can be negated in PP, but I wasn't too confident with the IQ. However I am very much a noob with this setup and I have seen great results from others.
It's also worth noting that the software graduated filter available in Lightroom is pretty good; however that means you would need to choose your exposure pretty carefully. This is assuming you don't do any bracketing or HDR etc...
10-24-2010, 02:42 AM   #6
Hi guys,
Did we ever find a conclusive answer to this? I'm looking to pick up a Cokin kit for my 15mm (probably from Adorama so I can pick up some other bits and pieces like film) and it would be great to get a guide of what to get.
cokin, da, da 15mm ltd, gnd, k-mount, ltd, pentax lens, slr lens
Pentax DA 15mm -and use of filters phb49 Pentax SLR Lens Discussion 0 07-17-2009 03:06 AM
GND filters online simons-photography Photographic Technique 6 10-31-2008 05:35 AM
For Sale - Sold: Tiffen Thread mounted GND filters Ed in GA Sold Items 3 04-21-2008 06:06 AM
All times are GMT -7. The time now is 02:24 AM. | See also: NikonForums.com, part of our network of photo forums!
