Thanks for all the replies.
Originally posted by raider I think you already have a good lens setup. I notice that they are all fast lenses.
Thanks Raider. I tried to "invest" on lenses following the suggestions from many ppl. Buy the fast lenses so no need to upgrade later on.
Originally posted by mel Critical depends entirely upon your needs. I have one and I can say it's a good lens choice for some applications, overkill for others. I think it's entirely unnecessary for portraits. I use mine mainly for shooting performances in low light from a little distance away and some wedding work.
Thanks Mel. That's what I'm thinking...maybe use the 70-200 for wedding.
Originally posted by Ash Mate, you won't get better for weddings than a 50-135 or 70-200 lens, regardless of brand. Your choice of focal lengths - I've personally found it a virtue getting the extra reach of a 70-200 lens, but there are many who do just fine with a 50-135.
No other AF telezooms for Pentax rival these in any way. The zooms are simply more versatile and make your job so much easier than having to rely on a fixed-focal length lens. You could make do with your 28-70 on one camera and the 85/1.4 or 135/2.8 on the other, as I have done similarly in the past before investing in the 70-200, but you may find you miss out on some of the spontaneous shots from a distance by not having that zoom capability.
Thanks mate. That's exactly right...I've tried using the 85 or 135 but they are not versatile enough.
Originally posted by Peter Zack I'm curious about what the 28-70mm is? The Sigma? If so, get rid of it. I've had a chance to test this lens out a couple of times and was unimpressed with the quality. Get the Tamron 28-75 f2.8 XR Di. A superior lens all around. Better flare control, more natural colour (the Sigma tends to have a yellow caste) and the Tamron is sharper. If you have the Pentax version, then it's a great lens and well worth owning.
What 85mm? If your lenses are MF, I'd seriously consider replacing these with anything you can get that is a top quality AF lens. MF is just too tough on a DSLR in low light. The screens are not bright enough and unless you have a Katz eye, there's no focus aid. Shooting portraits, MF is one thing, shooting weddinngs MF is another much tougher job.
As for the lens in question, I use a Sigma 70-200mm and it's a great lens. I wouldn't shoot a wedding without it. It's great for candid's, getting in close to the B&G without walking up to them and these days, more churches are restricting a photographers movements (too many hackers that don't respect the service). If you are stuck in the back of the church or on the sides, you must have this lens. The 50-135mm is a great option as well but I wanted longer than this. It's given me some of the best portraits/candid's of the guests from any lens.
My kit is similar to yours and the only addition is, I carry 2 bodies all the time. I have a 3rd in the car as a spare (all of equal quality). Also are 4 flash heads and battery packs with wireless triggers.
One body will have the Tamron and the other with the 70-200mm. I'll often switch the Tamron to a 16-50mm. In tougher light or depending on the situation, each camera will have a fast prime, with the zooms at the ready.
Peter, they are the FA 28-70 and FA 85.
I have a K7 and an *ist DS as back up (might pick up a K20D later).
What fast prime do you often use?
Do you need to use 3 bodies? 2 for zooms (17-50 and 70-200) and 1 fast prime?
I'm hoping to get a second shooter / assistant to help with weddings.
cheers
