Until this week I owned 2 adaptors: one genuine Pentax bought at a sell-out for a low price some 20 years ago, and only recently one of unknown make from an eBay seller (less than € 10.-, surely chinese manufacturing). I like to have the adaptors fixed at the lenses, to make changing lenses between m42 and KA faster, so I need one adaptor per m42 lens. For a while, a was frequently bidding on nearly all offers on eBay, waiting for a good deal. I finally succeeded with an offer for a new one by the german internet store Photo Walser (€ 10.85 including shipping) and was very astonished to get an "inner flange" one. The writing on it says "KIPON".
The "inner flange" works perfectly in pushing the auto pin; I was a bit afraid of damaging the body, as the "inner flange" seems to touch the power zoom contacts (just touching without putting force on the contacts), but no negative effects. Do they get voltage only if the body detects a power zoom?
EDITED: I just realized there is an opening in the "inner flange" (you can see it in the 2nd picture) preventing the powerzoom contacts to be shortcut once the adaptor is in its working position. So, if you switch off during lens change there shouldn't be any danger.
Comparing the 3 models [1]=Pentax, [2]=Noname, [3]=Kipon:
1) None of them fits perfectly, tolerances of [2] probably worst, often difficult to insert in the body.
Removing can be tricky with all 3 of them, even with [1] it is sometimes VERY difficult (I remember, years ago on my Super-A, I once needed half an hour).
2) In all 3 cases, cause of the difficulties is the spring: after getting rid of it, all 3 can be inserted and removed quite easily. As a result, the lens is now not securely fixed at the body. You need to drill a hole in the flange of the lenses so you can use the standard body/lens locking. If one uses one adaptor per lens, this would be the best solution (of course, if you don't carry a K-mount AND a m42-body with you and are interchanging m42-lenses between the 2 bodies).
3) All 3 adaptors do tilt the lenses; they are stopped too early, so shimming would worsen the problem - but to me, moderate tilting is not a problem. Nearest to 0 is [1], the other two are stopped 10-20 degrees early.
I will try to get another of these Photo-Walser adaptors, but as the description does not mention the "inner flange" and the picture does not comply with the item delivered, the next one I will get may be from another manufacturer. Also, at the moment Walser is only offering a limited number at € 14.95 (fixed price including shipment within Germany), with an option to offer a lower price. I tried, but they did not agree to any sugggestion lower than € 14.95. In their shop (outside eBay), they offer them at a much higher price.
Added pictures of the "KIPON" adaptor [3], the spring still attached.
