Originally posted by magkelly Does the manual even talk about adapters and using M42 lenses? I'd be very surprised if it did. Give the guy a break here. He's not just trying to use the camera in the accepted way with new digital lenses that are made for this camera. What he's doing takes a bit of practice and if you've never had a DSLR or used an adapter before I would imagine it would take you a bit to get it right.
No, you're correct in that the manual probably does not explain how to use M42 lenses and adapters. But the OP isn't have any problems with the adapters or the M42 lenses, is he? Under exposed photos are caused by the camera body, not the lens. It seems the OP has a hard time using the M/Av modes to its potential.
The manual does explain in pain staking detail on how to correct under exposed photos by adjusting the shutter speed and/or exposure compensation in M/Av/P modes. So yes, it would help tremendously if he were to read the sections in the manual that explains the manual mode.
