09-03-2010, 09:24 AM   #1
DA 70mm Ltd. 'Clunk'
My DA 70 seems to have a loose front element; when applying light finger pressure to the filter ring the front of the lens clunks very slightly to the sides - it's really obvious when the screw-in hood is attached. It's hard to tell by eye, but I'm pretty sure that the entire front element moves with it. I'm assuming this is a bad thing, as the lens' elements should stay parallel to the sensor, no?
It still takes good pictures, though...anyone else with a DA 70 seen this?
Pete
09-03-2010, 09:36 AM   #2
shiner's Avatar
I think they all do this- not to worry, although admittedly it drives me nuts if I obsess about it...
09-03-2010, 09:41 AM   #3
irishwhite's Avatar
QuoteOriginally posted by bikecoboss Quote
Pete
You're absolutely right. It's broken. just for display purposes, I will take it off your hands for $50 plus the cost of shipping
09-03-2010, 09:59 AM   #4
farfisa's Avatar
I don't know about the DA 70, but on a lot of lenses the ring where the lens info is printed screws in.
If it's under warranty, I'd send it in.
If not, you can take a rubber pad or glove (trying not to touch the front element), and maybe you can screw the front ring clockwise a bit, and that might tighten it up.
da, da 70mm, element, front, k-mount, lens, pentax lens, slr lens
Beginners question about noise (clunk) in a Pentax DSLR DV8 Troubleshooting and Beginner Help 62 09-25-2013 06:04 PM
K7 internal clunk noise grouse Pentax DSLR Discussion 12 04-21-2010 04:02 PM
Used K-x body clunk, gross fungus stuff? Cybe Photographic Technique 11 01-28-2010 08:07 AM
Pentax K7 clunk kiamon Troubleshooting and Beginner Help 13 12-26-2009 08:34 AM
i got a clunk shed301 Pentax DSLR Discussion 13 01-03-2009 06:13 PM
All times are GMT -7. The time now is 04:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
