Originally posted by scathontiphat i've had my 31mm ltd now for about 5 months now. It gets tons of use and the hood has started to come loose and it rattles around a bit now. Any advice on what I can do about this? thanks!
Hello Scat .... whatever Sir, here is an easy fix. Get a tube of Araldite (or any twin liquid epoxy pack). Take 2 drops of each and mix it well. Use your fingers to apply a light coat around the mount diameter. Use a tooth pick to apply some to the (2) recessed split catch area - the tabs that click-locks into place on the lens groove.
Make sure it is a light coat - just a smearing touch, otherwise it will drip down.
Let it dry for 24 Hours. Then apply another coat. You are done.
Try attaching the hood to the lens. If it is still loose repeat the process.
Good Luck.
Please do let other Pentaxians know if this works.
