09-18-2010, 07:38 AM   #166
I am with a friend and found that his Nikkor 35/1.8 is really very good at 2.5 aperture. I will wait to see what 35/2.4 will be like wide open at 2.4. I feel it won't be as good as nikkor 35/1.8 at 2.4/2.5. But it still have the size advantage.
09-18-2010, 07:48 AM   #167
ogl
ogl's Avatar
QuoteOriginally posted by kales Quote
DA35/2.4 will be good at f/2.4 like FA35 is sharp from wide-opened.
09-18-2010, 07:57 AM   #168
QuoteOriginally posted by ogl Quote
After I saw the actual photo of 35/1.8 nikkor, I really doubt that 35/2.4 could reach nikon, even it's sharp.
09-18-2010, 08:10 AM   #169
falconeye's Avatar
The irony is that this Nikkor 35mm is an APSC lens and that (AFAWK) this Pentax 35mm is a full frame lens
So, the Pentax lens has its own merits.
09-18-2010, 08:40 AM   #170
ogl
ogl's Avatar
Why? Did you see FA35?
DA35 has the same optical design.
09-18-2010, 09:34 AM   #171
ytterbium's Avatar
It's not all about sharpness and resolution. No sharpness can beat the sense of depth, space and 3-D effect you can achieve for example with sigma 30/1.4. Even if the resolution at the edges is crap - that's not the part of the image your'e looking at. The subject gets obviously separated, you can have much more composition flexibility etc. And the resolution is bad only at the very edges, at F1.4 subject will be plenty sharp even if not dead center (e.g placed at golden mean).
Or give coating/distortion/optic control. If they are really good, you get what you see in real life. E.g. no flares, hazing colour casts or fringing even in strong contrast situations. Correct geometry, no light falloff and other optical characteristics unrelated to DOF and resolution can give great sense of presence, if they are good. The image feels like "in your face" instead of just "picture". Even instantly invisible visual defects detach you from the actual scene.
E.g. the ugly fringing in highlights/bokeh of FA35, instantly make you perceive it as a photograph - optically manipulated representation of the scene.
Btw..
Even greater irony is that Pentax has no official plans for FF camera. So you like to pay for something you won't be using anyway. You may say film, but if the performance is "as good" as some of the DA LTD's that get blurry and distorted at edges on film, thats not a real "coverage".
09-18-2010, 01:19 PM   #172
Blue's Avatar
On what basis to you base your doubt? If the DA 35/2.4 is equal to the FA, then it is capable. It could even be a little better than the FA.
09-18-2010, 01:35 PM   #173
Ash
Community Manager
Ash's Avatar
QuoteOriginally posted by ytterbium Quote
Depth, space and 3-D can still be rendered at f/2.4
If it's not for low-light shooting ability, then f/2.4 is plenty enough for background separation. I can even recall shooting with a P&S film cam with a fixed f/8 35mm lens that I could get decent selective focusing between near and far objects in the frame. That's more than 3 stops down!
How about trying it out? Find the situations you shoot at f/1.4 with the 30mm and stop down to f/2.4 for those same scenes to see if you lose much of that depth control and 3-D effect you're after in the results...
09-18-2010, 06:40 PM   #174
Class A's Avatar
Would you say the same about a 54/3.7 on FF?
Because that's what the 35/2.4 on APS-C is in equivalent terms.
No doubt the difference between f/1.4 and f/2.4 is very noticeable. Whether one needs it, is another matter.
09-18-2010, 07:52 PM   #175
3D effect is dependent on a number of things. The DA 35 is very able to give this effect at f2.8, because of its ability to close focus. As to whether or not the DA 35 f2.4 will be able to do the same is debatable; however, the full frame equivalency issue is a red herring.
09-18-2010, 10:11 PM   #176
ovim's Avatar
Just checked a finnish/swedish webstore cyberphoto.fi and they have the 2.4/35mm listed with a price of 202e. They also have Pentax SMC-FA 35/2,0 AL listed at 842e...
09-19-2010, 02:02 AM   #177
ytterbium's Avatar
The 1.4/DOF thing wasn't my main point anyway. What changes with F stop is the working distance, to get decent separation. With 1.4 I could shoot person in full length and get a background blur that is not just barely bordering the circle of confusion size. Btw i don't have the sigma anymore, it had horrible AF issues. Thats one of the areas where i expect improvement in DAL35.
The F2.4 really will give plenty of DOF control in most situations, just not as much. What will be more important are the other factors i've mentioned. E.g. if the lens is really after FA i'd hope the CA/PF has been fixed. At F2.4 performance of DA Ltd's would be much more welcome.
09-19-2010, 03:29 AM   #178
QuoteOriginally posted by ovim Quote
Funny how prices develop, they also have Zeiss Distagon T* 35/2,0 ZK for 977 euro, just a good hundred more than FA 35. (FA 31 Ltd is 1278 euro there)
09-19-2010, 02:58 PM   #179
Class A's Avatar
No, it shows how sloooow the lens really is on APS-C. It's a prime for Pete's sake.
Since it isnt' WR and hasn't got quickshift either, the only point in its favour is the size. I hope it works for some; I think an affordable FA50/1.4 was a better way to make people buy further primes.
09-19-2010, 06:45 PM   #180
Maybe so, at least for some people. The 50 mm focal length didn't work too well for me and I didn't shoot that particular lens much wider than f2.8 anyway, so I guess it didn't really work for me.
As far as depth of field goes, there really isn't that much different between f2.4 and f1.8 at 35mm. Shooting a subject 3 meters away, at f1.8 you will have a depth of field of .55 meters and f2.4 a depth of field of .7 meters.
The biggest reasons to shoot primes at this point are for edge to edge sharpness, bokeh and small size. Otherwise, zooms match up well. In most situations, I would far rather shoot at f4 and bump my iso than open up the lens too wide and have out of focus shots.
judgement, k-mount, lens, move, pentax lens, people, quality, slr lens
A Spring Perspective IowaBoy Post Your Photos! 1 04-28-2009 10:10 AM
Perspective vs. FOV Chaoron Pentax DSLR Discussion 34 09-29-2008 02:29 AM
urban perspective.... JrPentax Photographic Technique 8 03-27-2008 05:21 PM
Perspective.... clarenceclose Post Your Photos! 6 02-16-2007 05:00 AM
All times are GMT -7. The time now is 10:45 AM. | See also: NikonForums.com, part of our network of photo forums!
