I guess it's not my first prime, technically. I've got an old M 50mm, f/2 that was the kit lens for my K1000. But I don't like to use it much with the K100D, because the combination of manual focus and manual aperture support gets tiresome after a while. I know, it's not sophisticated or honorable to eschew manual lenses...but so be it.
After using my 18-55mm kit lens stuck on a few different focal lengths, I've decided that a 35 or 40 mm makes a good walk-around, normal lens. I guess that should come as no surprise. I notice that there are two lenses that are in my sweet spot from a feature and price standpoint.
The DA 40mm is small and light, less expensive, and supports quick-shift focus. It looks a little funny mounted on the camera, but kind of cool at the same time. The reviews here on PF are top-notch, as well.
The FA 35mm f/2 is a stop faster and has just a little wider view. Word is, it's a pretty good piece of glass in its own right. And if there were nothing else different between the two lenses, I might prefer the perspective of 35mm for general shooting.
So is there any input you all can give that might steer me one way or the other? Are there major differences in AF speed or image quality to worry about? Or is it simply worth it to pay for the faster lens?
