09-13-2010, 08:08 PM   #1
Eruditass's Avatar
17mm vs 18mm (Tamron vs Sigma f/2.8 zooms)
How big of a difference is there on the wide end of these two lenses?
I've heard Sigma's 18mm is more like 19mm, but has anyone done a real comparison?
I saw brickwall tests here but it's kind of hard to tell with that kind of shot.
09-13-2010, 09:29 PM   #2
I think angle of view is what you are looking for:
78.8-31.2 for the Tamron 17-50 f2.8
69.3-27.9 for the Sigma 18-50 f2.8 EX DC Macro
72.4-27.9 for the new Sigma 17-50 f2.8
So the Tamron has the widest angle of view.
Regards,
Peter
09-13-2010, 09:49 PM   #3
Eruditass's Avatar
Thanks for that information, it's helpful, but I want to see what it means in a scene.
09-14-2010, 12:23 AM   #4
QuoteOriginally posted by Eruditass Quote
I think that's asking the improbable. I don't think anyone would buy two fairly expensive lens with almost identical zoom range and speed to just to see which one has the widest angle of view. I certainly would not, but given the information kindly provided by Doanh I would be more inclined to buy the Tamron instead of Sigma.
Thanks,
09-14-2010, 04:57 AM   #5
bdery's Avatar
The Tamron is seen as the best of the two, generally. And the 16-50 from Pentax better than either.
I have the Sigma 17-70 and the Pentax 18-55 and I can confirm that 1 mm at the wide end is quite noticeable.
09-14-2010, 05:51 AM   #6
GeneV's Avatar
I don't have time to do it right now, but the differences given in the post above have me wanting to shoot a comparison in angle of view at 17 mm between my Pentax and Sigma zooms. Six degrees difference in angle for two lenses at 17mm seems like quite a bit.
09-14-2010, 09:12 AM   #7
Jewelltrail's Avatar
GeneV: I don't have time to do it right now, but the differences given in the post above have me wanting to shoot a comparison in angle of view at 17 mm between my Pentax and Sigma zooms. Six degrees difference in angle for two lenses at 17mm seems like quite a bit.
The published AOV for Sigma, I believe, is due to their using their sensor (in the Sigma camera) in the calculations. 17mm is 17mm.
09-14-2010, 02:53 PM   #8
Eruditass's Avatar
QuoteOriginally posted by excanonfd Quote
Thanks,
Many people have had both of these lenses at the same time and did many comparisons, usually focused on sharpness. So, I would not consider it improbable.
Thanks,
09-14-2010, 02:55 PM   #9
Eruditass's Avatar
QuoteOriginally posted by Jewelltrail Quote
17mm is 17mm, but advertising is advertising.
Tamron 17-50mm F2.8 XR Di-II Test Photo Gallery by lightrules at pbase.com
Sigma 18-50mm: 18.80-50.55mm f2.99-3.03.
Tamron 17-50mm: 17.36–50.37mm and f2.74–2.93
09-14-2010, 03:13 PM   #10
Now, what about their actual t-stops?
09-14-2010, 04:54 PM   #11
GeneV's Avatar
Yes and no. On a zoom, sometimes 17mm is 16.8mm and sometimes it is 17.4mm. As someone else said, avertising is advertising.
09-14-2010, 07:43 PM   #12
QuoteOriginally posted by GeneV Quote
I don't think that's at all unique to zooms.
Paul
09-22-2010, 11:05 AM   #13
GeneV: Yes and no. On a zoom, sometimes 17mm is 16.8mm and sometimes it is 17.4mm. As someone else said, avertising is advertising.
Zooms are, of course, dependent upon where they are focused: 50mm focused at infinity is not the same 50mm focused elsewhere. AOV is calculated with the sensor dimensions in the mathematical formula. It is expected that Sigma publish figures with its sensor.
18mm, k-mount, pentax lens, slr lens, tamron vs sigma, vs
For Sale - Sold: Exceptional zooms - Tamron 17-35mm di and Sigma 70-300mm apo di tundraguide Sold Items 5 07-17-2010 05:04 PM
Sigma or tamron 18-200 zooms TheGrandPrixKid Pentax SLR Lens Discussion 1 09-10-2009 09:11 AM
Which one of the 3 zooms would you keep: Pentax,Tamron, or Sigma 41ants Pentax SLR Lens Discussion 4 08-24-2009 06:24 AM
Tamron SP AF 11-18mm 4.5-5.6 Di II LD Asp IF Review kyrios Pentax SLR Lens Discussion 4 10-20-2008 10:24 AM
Comparing Sigma/Tamron/Tokina f2.8 APS-C zooms kjao Pentax SLR Lens Discussion 0 05-04-2007 04:16 AM
All times are GMT -7. The time now is 10:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
