09-03-2007, 01:22 PM   #1
New DA21: Advise on How to Test for BF/FF
I will be receiving a new DA21 this week.
Could you advise me on how to test for possible BF/FF issues when I receive it?
I remember Ben had to return a couple of copies of this lens.
Thanks in advance
Sam
09-03-2007, 01:40 PM   #2
sft
sft's Avatar
Take Pictures
Seriously though - just take normal shots and see if the focus point is indeed what you focused on - you'll notice if it is not focusing properly. Also older DA21's sometimes seem to act in a weird way - focus at f/3.2 and take the shot - then change aperture to something smaller than f/5.6 - say f/8 and half press and AF and without letting go of the half press & AF change aperture back to f/3.2 and take the shot. The sharpness should be the same in both the normal f/3.2 shot and the focused with f/8 but taken with f/3.2 shot. Mine is a newer batch and does not exhibit this or any other problem and I would expect yours to be fine as-well.
09-04-2007, 09:11 AM   #3
Sam
I will check it out as soon as I receive it.
Thank you!!
Sam
QuoteOriginally posted by sft Quote
Take Pictures
09-04-2007, 06:17 PM   #4
If after taking photos you think you may have a problem, use this link to read about and print a chart to photograph. http://http://focustestchart.com/chart.html I have a lens that I noticed an issue on when I was using it wide open; I then confirmed it using this chart. I resorted to the chart and a tripod to be sure that it wasn't "user error". I also checked several other of my lenses at the same time. The differences in results definately confirmed my one lens had a BF issue.
09-04-2007, 06:23 PM   #5
09-04-2007, 06:27 PM   #6
If after making some photos you suspect an issue you might want to check out this site and use the chart to confirm http://http://focustestchart.com/chart.html
bf/ff, da21, k-mount, pentax lens, slr lens, test
DA21 against Sigma 10-20 (v1)? axl Pentax SLR Lens Discussion 9 12-29-2012 09:34 PM
Anyone own the DA*16-50 & DA21 pcarfan Pentax SLR Lens Discussion 6 12-26-2009 08:36 AM
DA*16-50 vs DA21 Ltd dugrant153 Pentax SLR Lens Discussion 9 03-01-2009 11:15 AM
DA*16-50 vs DA21 @ 21mm? Gooshin Pentax SLR Lens Discussion 9 03-04-2008 03:39 PM
DA 12-24 vs DA 14 + DA21 and Pentax SLR Lens Discussion 19 07-18-2007 08:30 AM
All times are GMT -7. The time now is 01:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
