09-19-2010, 07:45 PM   #1
rortiz's Avatar
M 50 F1.4 and K20d Problem
Hi,
I wonder if there are any of you who have problems with using the K20d and A 50 F1.4. I've had the shutter release freeze on me a few times. This seems to be an intermittent problem. I've since found out that when I turned on my K20d after mounting the 50 then scrolled through a few focal lengths first before choosing 50mm to tell the camera what lens was mounted on it, the problem would disappear.
Does anyone have the same problem? What about other lenses in the M range? I ask because you can usually purchase a used M lens for a very good price and the quality of the optics is quite good.
Any feedback appreciated!
Cheers,
Ramon
09-20-2010, 02:09 AM   #2
I use a few M lenses on my K7 without any problem. The shutter fires fine no matter which focal length is specified.
You have to make sure the aperture ring is set to "A" and the focus mode is set to "M". (Sorry if this advice is too trivial.)
09-20-2010, 02:20 AM - 1 Like   #3
pschlute's Avatar
With the M lenses and the camera in AFS mode, the shutter wont release unless the camera thinks it has focus lock. So you need the green hexagon lit. This can be used to your advantage by using it as a "catch in focus".
If like me you want full control over the shutter with Mlenses, make sure the camera is in manual (focus) mode.
09-20-2010, 10:02 PM   #4
Hi Ramon, think Peter is on to something there,have had mine long enough to make
me sound old. guess theres couple of ways to 'fix', as Peter suggest or disable
catch in focus in custom menu selection. that nifty 50/1.4 is my favorite.
Bill
09-21-2010, 05:26 AM   #5
rortiz's Avatar
ilan, Peter and Bill,
Thanks for your advice. I now know what I was doing wrong - I hadn't switched the AF to manual. This explains the intermitten nature of the problem. The shutter fired when I was spot on with my focussing but did not when I was off. Makes sense!
Ramon
09-21-2010, 09:24 AM   #6
QuoteOriginally posted by rortiz Quote
Ramon
Welcome to the world of Catch In Focus (focus trap). Set your camera to AF-S, press the shutter release while turning the focus ring. As soon as it sees focus, the shutter will trip. I think you have to turn it on in the custom menu for it to work though.
f1.4, k-mount, k20d, lens, pentax lens, slr lens
Just got my K20D... problem already - need help! dimak Troubleshooting and Beginner Help 6 05-01-2009 04:21 AM
K20D AF problem benjikan Pentax DSLR Discussion 19 03-27-2009 03:32 PM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
SR problem on K20D ivanp Pentax DSLR Discussion 16 06-18-2008 05:46 AM
K20D problem ariahspam Pentax DSLR Discussion 6 06-06-2008 12:10 PM
All times are GMT -7. The time now is 12:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
