09-24-2010, 04:19 AM   #31
I doubt highly that Pentax will phase out in body motor within the next ten years. Considering the number of primes that require in body motor, I have to think that the majority of limiteds sold are for lower end cameras. Now, if Pentax ever released an EVIL camera, I think in lens motors would be the only option...
09-24-2010, 06:54 PM   #32
I recall a Minolta 28-135mm F4-4.5 lens, whose optical qualities rivaled the Zeiss and G lens. I have high hopes for this lens.
This and hopefully a 55-300mm WR wouldnt be a bad travel combination.
03-20-2011, 04:11 AM   #33
I have a k100 d and bought this lens, expecting the AF to work. It isn't currently. Any way to fix this issue so that it will work or am I stuck with a manual only lens now?
03-20-2011, 04:30 AM   #34
Vangelic... your K100D is obsolete. I suggest you get a more modern camera like the K-x...
For AF to work, the lens and camera need to communicate electronically or mechanically. The K100D lacks the ability to communicate electronically, the lens lack the ability to connect mechanically.
03-20-2011, 05:51 AM   #35
audiobomber's Avatar
QuoteOriginally posted by Vangelic Quote
The first post in this thread contains a quote from the 18-135 press release:
"This lens is compatible with the PENTAX K-5, K-r, K-7, K-x, K-m, K20D, K200D, K100D Super and K10D (with Ver. 1.30 or later firmware installed) camera bodies. When mounted on other camera bodies, the focus mode is automatically switched to manual."
autofocus, bodies, camera, construction, distance, focus, k-mount, lens, pentax lens, screwdrive, sdm, slr lens, water
General rule for step-up step-down rings? uchinakuri Pentax SLR Lens Discussion 2 06-18-2010 09:54 PM
Step up or Step down ring for FA 50mm f1.4 and filters. Xcom Pentax Camera and Field Accessories 4 05-11-2009 11:56 PM
Starting with the Eye and Working Backwards mithrandir Photographic Technique 13 07-18-2008 09:06 PM
A Step-by step guide to using M and A Lenses krs Pentax DSLR Discussion 33 03-18-2008 07:21 PM
backlit and backwards NaClH2O Monthly Photo Contests 0 03-07-2008 07:13 PM
All times are GMT -7. The time now is 07:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
