09-21-2010, 03:11 PM   #1
hockmasm's Avatar
When/How to use Macro Switch?
just got my Tamron 70-300!
It has a macro switch, when and why and how do I use it? i flipped the switch and see no change.
09-21-2010, 03:37 PM   #2
rfortson's Avatar
Not sure what function the switch uses, but I'll take some guesses and you can try them out to see what is correct.
First of all, turn the switch off and then see how close you can focus to an object when fully zoomed out. Next, turn the switch on and see if you can focus closer. That's typically all "Macro" means on a zoom lens, the ability to close focus while zoomed out.
The other possibility is that it might be a focus limiter, meaning it restricts the AF movement to something close to the lens, and prevents it from focusing all the way out to infinity (something you'd rarely do if you were shooting macro).
Either one of these possibilities should be easy to test. Let us know what you learn.
09-21-2010, 11:44 PM   #3
I've got the same lens. The macro switch is a bit weird to get used to.
To switch from normal > macro you must be zoomed between 180-300 (there's a gold line there). Once that is engaged, you can focus even closer, as indicated on the focus ring by the numbers with a gold line under them.
To move the macro switch back to normal, you have to turn the focus ring (remember to disengage AF! no quick shift here) past 1.5m/4.9 ft and then you'll be able to move the switch.
09-22-2010, 12:08 AM   #4
QuoteOriginally posted by mikem Quote
Exactly..
Taken at 180mm
Taken at 300mm
Neither image is cropped.
Enjoy your new lens.
09-22-2010, 08:34 AM   #5
Ahab's Avatar
QuoteOriginally posted by hockmasm Quote
You might want to read the insruction sheet.
09-22-2010, 09:24 AM   #6
It allows you to focus closer.
</thread>
09-22-2010, 05:11 PM   #7
hockmasm's Avatar
it didnt come with instructions. used from ebay.
so can you use macro if you are zoomed into 300 and trying to focus on a bird really far away? or is it used more fr zooming in to an object close to you?
09-22-2010, 05:42 PM   #8
Either / Or. The 300mm photo I show was taken standing at about 4 feet from the bolt as was the 180mm.
09-22-2010, 09:56 PM   #9
Macro mode allows the lens to decrease the minimum focus distance. Think of it as reading glasses for old eyes. No more holding the book at arms length, bring it in close and see it big.
09-23-2010, 03:59 AM   #10
</thread>
k-mount, macro, pentax lens, slr lens, switch
I can't switch on my K-x Camera limweeteck Pentax Camera and Field Accessories 10 08-06-2010 10:03 AM
Cable switch, k-7? ( RS-C1 ) pajic3 Pentax DSLR Discussion 0 10-03-2009 05:46 AM
Light switch beep41 Post Your Photos! 2 05-21-2009 01:40 PM
Switch To Another Brand? pentaxshooter General Talk 40 09-11-2007 06:44 AM
All times are GMT -7. The time now is 02:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
