Thanks for the reply.
This was just one example. I used iso 800 in an attempt to isolate wether the problem was the lens focusing, my movement, or some other camera problem. I was trying to eleminate any handheld jitter effects. But the results are the same no matter what ISO or automation I select. I think you have a good suggestion about zooming back a bit. I did not purchase this lens for taking bird pictures, simply got inot it for my sis and the focal length is really too short for that. Possibly I should try a 300 mm lens and see what kind of results I get.
None the less, I do feel that the results from this lens at infinity are kinda crummy, at least at the 200mm focal length.
I think that holding the camera still is something I do well. Using a monopod might work, but even when setting my camera on the old Ford PU the results are very similar.
Anyway, I do appreciate all the help. I was approaching this issue from the angle of what might be wrong with my lens/camera. I have taken pictures with my sis's Canon XTI and 70 300 zoom Canon is zoom lens under similar conditions and they seem very much sharper. But that is comparing a $1800 camera to a $650 camera.
It is a case of the bumbling leading the blind. She has retired and started a hobby of bird photography. I have been a rank amateur for too many years and am trying to help out. Together we have improved our pictures, was just wondering why my Pentax is sooooo far behind her Canon in image sharpness. She uses Photoshop and usually just accepts the default automatic enhancement, I use a iMac (no laughs please) and use SilkyPix and iPhoto.
None the less, we are accomplishing the job of cataloging the birds in the area, even recorded a few surprises! Photograph is fun, even for rank amateurs.
ALL KINDLY CONSIDER MY QUESTION CLOSED...
Reason: close out topic
