09-23-2010, 05:17 AM   #1
ismaelg's Avatar
The war has begun! 300mm vs 500mm
Hi,
It was a matter of time before these 2 took a fight!
On one side the DA L 55-300: Modern, sleek, excellent optical quality and resolution.
On the other side: the SEIMAR 500mm f8: old, screwmount, big, heavy, cheap lens, but with the muscle of 500mm focal lenght.
I know these are two very different beasts and it is not even fair to compare them, but what the heck!
The Moon was beautiful and the skies were clear for a few minutes, so these two went out and shot a few rounds.
DA L 55-300mm No crop
SEIMAR 500mm No crop
How about 100% crop:
DA L 55-300 100% crop
SEIMAR 500mm f8 100% crop
Conditions were not exactly identical either.
Camera: Pentax K100D Super
Minor post process in CS5 (about equal sharpening on both)
Lens:-----55-300mm----500mm
shutter spd:---1/80s---1/20s
aperture:-----f8--------f11
tripod:--------yes-------yes
2 sec delay
Mirror
Lock up:------yes------yes
wire
remote:-------no------yes
ISO:----------200-----200
The 300 has the resolution, the 500 has the muscle
Conclusion: I'm having FUN!
Verdict: Absolutely NONE!
What do you think?
Thanks,
09-23-2010, 05:21 AM   #2
Jasvox's Avatar
I agree wholeheartedly with your conclusion and your verdict!
Jason
09-23-2010, 05:59 AM   #3
Moderator PEG Judges
Kerrowdown's Avatar
With your conclusion and verdict..................................................................
Well, I think you should be let loose on loads more lens testing/comparison web sites and magazines.
Perhaps it would bring a few smiles to others as you did to me, keep up the good work.
09-23-2010, 08:36 AM   #4
You didn't use the wired remote with the 55-300?
That Completely blows your test..
(just in case you didn't get it)
:sarc:
The best conclusion I've seen yet in any of these compare tests. Both are decent shots.
09-23-2010, 08:59 AM   #5
ismaelg's Avatar
QuoteOriginally posted by JeffJS Quote
Exactly the point! I need an excuse to keep testing.
It was like a drag race: The slower one got a a 1 light lead
09-23-2010, 09:39 AM   #6
I wonder why you need remote if you use 2 second delay and mirror up?
09-23-2010, 10:10 AM   #7
ismaelg's Avatar
QuoteOriginally posted by Pigeon Quote
Hi,
With the 500mm just touching the camera creates some vibration and wobbling that takes more than 2 seconds to settle. The 12 second delay does not include mirror lock up so using the remote is the best approach. Not sure but I think SR is disabled with the MLU timer.
Thanks!
09-23-2010, 10:50 AM   #8
unixrevolution's Avatar
Up next: Super-Takumar 35mm F/3.5 Vs. SMC-Pentax DA L 35mm F/2.4?
09-23-2010, 11:14 AM   #9
Hi,
Thanks!
SR is disabled in Several modes especially those where Pentax assumes you'll be using a tripod. This has been true for quite some time.
I use something a little longer for Moon shots, a Vivitar 600-1000 mm f9 point something and at 600mm, with a fast enough shutter speed (will require some processing) can get it hand held (with the K7).
The Heavens - a set on Flickr
500mm, crop, da, f8, k-mount, muscle, pentax lens, resolution, seimar, slr lens
500mm vs 300mm wjt Pentax SLR Lens Discussion 15 08-17-2010 05:34 AM
Sigma 50-500mm vs 150-500mm or Pentax DA 55-300mm with 1.4 TC? mikejustice Pentax SLR Lens Discussion 20 12-18-2009 07:59 PM
Samyang 500mm f6.3 mirror vs DA 55-300mm newarts Pentax SLR Lens Discussion 9 12-13-2009 02:39 PM
Sigma 50-500mm f/4-6.3 EX DG or DA* 300mm F4? Reportage Pentax SLR Lens Discussion 18 03-06-2009 10:53 PM
All times are GMT -7. The time now is 02:44 PM. | See also: NikonForums.com, part of our network of photo forums!
