09-28-2010, 05:08 AM   #1
fishy's Avatar
Loose spring in DA* 16-50mm?
Hi all,
after unpacking my suitcase, after a rather long flight, I find that my DA* 16-50 has a nasty sound / resistance when zooming out (exactly where the second sleeve starts moving) It sounds like a spring has come loose. Has any one else experienced this? I ordered the lens with Adorama two years ago, so I guess warranty is over, and where I live there's no repair shop (drawback of living in a developing country) so any advice is welcome!
Thanks
09-28-2010, 07:03 PM   #2
Giveaway winner!
MysteryOnion's Avatar
Did you look closely at the barrel for dents or deformations? This would be the most common thing wrong. You did not mention if the SDM is not working or even able to focus properly. Stand the lens, mount cap on, and turn it in the fully extended and retracted positions to see if it is bent or sitting funny. If it was in a case during the trip, was it a soft case or hard?
09-29-2010, 01:13 AM   #3
fishy's Avatar
Thanks for your reply. SDM no problem, but when I took it off the camera to check more in detail, two bits of metal came out (about 2 cm long, one messing-like the other more steel) semi circular flat bits with notches at both ends. No idea what they should be doing, but they're obviously not doing it any more
10-13-2010, 09:25 AM   #4
Giveaway winner!
Sounds like a E clip or snap ring? I've not looked inside a SDM lens, but in a zoom sometimes a spring is used to assist the return of a cam to position. Without it, the action will be tight or stiff or the lens will not travel to full adjustments.
da*, k-mount, pentax lens, slr lens
SMC Pentax-M f1.4 50mm loose front ring? theperception2008 Pentax SLR Lens Discussion 6 05-04-2011 08:06 PM
31mm - How loose is too loose? mmphilip Pentax SLR Lens Discussion 5 07-31-2010 02:34 PM
Tamron 17-50mm/2.8 Loose Filter Ring? Venturi Pentax SLR Lens Discussion 4 06-18-2010 06:57 AM
Lens loose inside 50mm f1.4 waltzcore Pentax SLR Lens Discussion 4 09-24-2009 08:47 PM
All Hands on Deck...Spring Has Spring!! VaughnA Post Your Photos! 6 04-18-2009 01:43 PM
All times are GMT -7. The time now is 08:40 PM. | See also: NikonForums.com, part of our network of photo forums!
