Originally posted by lensego Hi Guys
It might be a silly question
What is going to happen if you use an image stabilized lens with a stabilized body ( K7)?
Am I gaining the extra stops what my lens is giving ? I.e. Tamron 18-270mm with
Vibration Compensation (VC) optical image stabilisation (up to 4 stops)
regards zoltan
No, since Pentax SR is not designed to work in conjunction with an optically stabilized lens and is not aware of the optical stabilization in the lens, having SR and in-lens IS enabled at the same time will make things work. That's why Sigma OS/Tamron VC lenses say to disable SR on Pentax bodies when OS/VC is enabled on the lens.
There's a lot of debate as to whether lens-based IS or body-based IS is better, at long focal lengths it seems like lens-based IS usually wins, and shorter focal lengths benefit better from body-based IS.
One definate advantage to lens-based IS is that the viewfinder view is stabilized and the AF system sees a more stable target. I definately see major improvements in AF performance at the long end of my Sigma 18-250 HSM OS when the lens stabilization is turned on.
