09-13-2007, 10:55 AM   #16
Handholding this lens is not terribly difficult as long as it's moderately bright. Here's a link to quite a few shots taken with the 300 hand held (some with other lenses but all are labeled). As you can see as long as you are careful with your basics, you can get some pretty good shots handheld.
https://www.pentaxforums.com/forums/post-your-photos/5813-kites-lots-images-some-replies.html
NaCl(there are quite a few more shots around, it's a popular lens in this forum)H2O
09-13-2007, 11:46 AM   #17
Lowell Goudge's Avatar
I don't disagree with hand holding, BUT, when used with the 1.7 AF TC you are discussing holding a 500 mm f/6.8 lens and usually (except when I use a flash on my *istD) there is never enough light.
ALSO the Adorama bracket supports the lens under the lens hood, which is flimsy, or directly uner the lens front group with the hood extended. This part moves when focusing, and as a result it cannot really be easily relied on for a firm mount.
Remember this is not an IF lens. The front group moves with focusing
09-13-2007, 03:06 PM   #18
roy
roy's Avatar
i wouldn't worry about it. the lens isn't that heavy. when i had the A*300 i hung it and my DS almost everywhere .. the zoo, the back country, just everywhere. it's a little heavier also and i never had a problem. the 300/2.8 actually has strap attachments on the lens.
09-14-2007, 07:12 AM   #19
Well I do not use a TC with the lens so available light usually isn't a problem with the kind of shooting I do with it. Also as I said in my post, I pre focus the lens before mounting it so that there is only minor fine focusing needed after mounting. I've had no problems with this proceedure.
NaCl(but it's not used all that often, mostly the lens gets hand held)H2O
09-14-2007, 08:11 AM   #20
roy
roy's Avatar
IALSO the Adorama bracket supports the lens under the lens hood, which is flimsy, or directly uner the lens front group with the hood extended. This part moves when focusing, and as a result it cannot really be easily relied on for a firm mount.
that was the A*300s problem.. even if you wanted to add a ring or rest there was no where on the lens that did not move
09-14-2007, 08:52 AM   #21
QuoteOriginally posted by roy Quote
Roy
Go back to my photo of the bracket.
This one does pick up the only non moving point (relitive to the lens mount) on the SMC-300 f/4.0. I would need to look at the SMC-A & SMC-M and other varients to see if they have a similar point
09-14-2007, 09:35 AM   #22
roy
roy's Avatar
lowell, if it could be made, i'd have done it.. i'm a real DIYer. there a BIG difference in the configuration between the two. yes. i may make one for my tak300.
k-mount, pentax lens, pentax smc, slr lens
The Pentax SMC 300/4 hrishi Pentax SLR Lens Discussion 111 12-07-2008 01:25 PM
Pentax-55 - 300-mm-smc-da- Lloydy Pentax SLR Lens Discussion 9 04-05-2008 01:23 AM
For Sale - Sold: FS: Pentax SMC A 70-210 f/4; SMC F 100-300 f/4.5-5.6 PaulAndAPentax Sold Items 2 02-10-2008 10:59 AM
Some more from the Pentax SMC 300 F4 NaClH2O Post Your Photos! 20 02-01-2008 03:49 PM
Tamron 70-300 Di Ld Vs Pentax SMC FA-J 75-300 senjakala Pentax SLR Lens Discussion 17 06-28-2007 10:57 PM
All times are GMT -7. The time now is 01:26 AM. | See also: NikonForums.com, part of our network of photo forums!
