10-04-2010, 08:45 PM   #1
Super Takumar 55mm F1.8 Focus Distance Scale
I'm having a great time with my mom's Spotmatic SP and Super Takumar 55mm F1.8 lens. The only nuisance with the lens is that the metal band that has the focus distances marked on it has come loose. In now spins freely within the lens body, such that when the lens is focussed at infinity (based on the hard stop), the focus index could be pointing at infinity, or 3 feet, or some other value, depending on the results of random friction forces as the metal band spins within the lens body. This also takes away from the smooth manual focussing feel of this wonderful lens.
Does anyone know if this problem can be remedied without disassembling the lens?
Thanks!
10-04-2010, 10:10 PM   #2
jatrax's Avatar
The distance scale on the Super Takumars is attached by three small (very small) screws that can be accessed from the outside. The screws press against the lens body and hold the scale in place.
It takes very little screw movement for them to come loose.
If the screws are still present then you need only adjust the scale correctly and re-tighten. If they are missing, well they are a bit hard to find.
Good luck!
55mm, body, f1.8, focus, infinity, k-mount, lens, metal, pentax lens, slr lens, takumar 55mm f1.8
Asahi Super-Takumar 1:1.8/55mm Lens won't focus to infinity bingostew Pentax SLR Lens Discussion 15 10-25-2012 08:19 AM
queston distance scale sigma 24mm 2.8mm AF bjan Pentax SLR Lens Discussion 2 02-27-2010 02:46 AM
Super Takumar 135mm f/3.5 and Super Takumar 55mm f/1.8 Fixcinater Pentax SLR Lens Discussion 21 08-30-2009 09:34 AM
Fuji Fujinon 1:1.8 55mm vs. Super-Multi-Coated Takumar 1:1.8 55mm carpents Pentax SLR Lens Discussion 6 06-27-2007 05:25 PM
All times are GMT -7. The time now is 01:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
