09-12-2007, 03:38 AM   #16
DMH
Kguru, I like your logic, makes sense to me. Gives us a constant value which compares what really matters, that is, how does it affect my photo.
09-12-2007, 06:02 PM   #17
QuoteOriginally posted by DMH Quote
Also too confusing, since so many different versions of "X" exist, and even the definition of "normal" for 35mm has a small amount of leeway.
Focal length is focal length, PERIOD, and is the number that should be on the lens. It should be up to the photographer to know whether or not they have a cropped field of view or not.
Many other aspects of a photo are still dependent on the actual lens focal length and not it's "35mm equivalent", such as depth of field. DOF remains based on lens focal length, not "35mm equiv" focal length, while field of view is based on "35mm equivalent" focal length.
That is to say that a 50mm lens will deliver the same DOF regardless of what sensor size it is used with. The field of view will differ depending on sensor size though.
09-12-2007, 07:46 PM   #18
SpecialK's Avatar
QuoteOriginally posted by Kguru Quote
In the "old money" 50mm was the mid-point between W(ide) and T(ele) so I tend to think:
17mm=3W, 20mm=2.5W, 28mm=1.8W
70mm=1.4T, 100mm=2T, 300mm=6T
With APS-C mid-point is 33mm therefore:
17mm=2W, 20mm=1.7W, 28mm=1.2W
70mm=2T, 100mm=3T, 300mm=9T
It's simpler to say 70mm in APS-C is 2x Tele rather than it's equivalent to 100mm focal length in 35mm system.
It also readily explains 28mm= 1.2x Wide is no longer very wide.
Actually, it you should change "T" to "S", and not use "W" at all, because the FL is a fraction or multiple of "S"tandard (human binocular field of view equivalent:-)
35mm, camera, cameras, chip, da, film, frame, k-mount, pentax da lenses, pentax lens, reference, slr lens
Sensor size v Pentax focal lengths wizofoz Pentax DSLR Discussion 18 10-12-2010 04:23 AM
Where can i see some focal lengths comparison rustynail925 Pentax SLR Lens Discussion 6 04-19-2010 04:21 AM
Tracking your focal lengths jct us101 General Talk 12 10-26-2009 05:29 PM
DA* and focal lengths emr Pentax SLR Lens Discussion 11 10-06-2009 11:51 AM
Focal lengths FOV roy Pentax SLR Lens Discussion 4 03-08-2007 08:35 PM
All times are GMT -7. The time now is 06:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
