Originally posted by JoepLX3 I can understand the "kick" of using graduated filters, doing it optical rather than digital, but am curious if is actually really needed for dynamic range or you just do it for the fun / habit.
Yes, they are really needed, if you don't want to be stuck to a tripod. To get a similar effect with HDR software as with a GND filter, you need to stack some tripodded shots. If anything moves, tough -- or you can pretend you're doing
Harris Shutter work, but that ain't the same.
Nope, if you want to shoot moving dark subjects under a bright sky, you *need* a GND, at least until silicon foundries produce sensors with region-variable sensitivity. I use a GND out of necessity, not for kicks. For kicks, I snort whipped cream. Doesn't everyone?
