Originally posted by Ron Kruger First of all, don't just look for focus. Go from one side, all the way through focus to where it just begins to blurr. Then go back through to the other side to where it begins to blur. Then slowly ease back into focus to where the image sort of pops.
Don't look at the entire image or subject to check focus. Pick one particular part, such as an eye. Don't look at or concentrate on anything else.
Some of the problem with using MF, however, has to do with the lens. You can't MF a kit lens. You need older lenses make for MF, Limited or * lenses that have smooth, accurate focus rings.
This is exactly what I do. I think my problem might be that I have contacts. When I stare really hard for a longer period of time these tend to blur our faster than when using glasses. Switching to glasses is not an option now since I'm comfortable with contacts that I only change once a month.
Also, I know exactly what you mean when you say you can't use new lenses for MF. The Sigma has an even shorter focusing ring and it really bothers me, it's really annoying when you want to focus manually.
Originally posted by klh I have had similar problems to what you describe, but recently installed a new focusing screen with a split screen and microprism ring. I bought it with the intent of allowing me to use MF with my older lenses as I did in my film days, but I found that it has dramatically improved my AF as well. Now I can clearly see what the AF is choosing, and make a change if it is not what I want. What I thought was a backfocus issue was really just the AF choosing the wrong subject to focus on.
I've also considered this but I would prefer a "quick shift" solution since I use auto focus alot and rely on my viewfinder to show me exactly what I want.
Originally posted by JeffJS Let's define then what you mean by 50-75 percent of the time your focus is correct. I was under the impression that was with a single lens. If the Sigma is off ALL the time then yes, you likely have a focus problem. From your description, it sounds like Back focusing.
Back focusing Ok, but I think it might not be that since I don't always have the problem and when I do tripod tests with good lighting I get a very accurate focus.
Personally I think that this lens has such a short focus ring that even the motor drive has problems to accurately focus enough for me. But ( !! ) when on a tripod it seems to be perfect, mostly...
This is a good example. I do a couple of tripod tests, pictures turn out perfectly. I take the camera off the tripod and aim at a subject, 5-10 cm off... Lighting is indoors during daytime.
