10-09-2010, 08:28 AM   #1
Pentax A 50mm f1.2 lazy aperture problem
Dear All,
I`d like your kind advice about fixing "lazy aperture" problem on my A 50 f1.2. The aperture closes too slowly when you fiddle with the lever, and it shows when taking pictures - overexposures, etc.
Usually there are two causes of this: sticky aperture blades and weak or misplaced spring. I think I have the second one because when looking at the blades carefully I`m sure they`re super clean.
Can someone offer me advice or maybe service manual for the lens, so I at least know how to begin fixing this, from the mount side or front side of the lens.
Also there is always possibility to bring it in for repair by local Pentax service-center.
10-09-2010, 10:56 AM   #2
ChrisPlatt's Avatar
Often you can't see oil on the aperture blades, but that is what I suspect is the problem with yours.
Any shop competent with camera lens repair should be able to repair yours quickly and cheaply.
Chris
10-09-2010, 07:59 PM   #3
They are probably all put together about the same way.. This May help..
http://www.pentax-manuals.com/manuals/service/smca5017.pdf
password is Pentax
from
Pentax Manuals
10-10-2010, 09:17 AM   #4
gofour3's Avatar
I had the same problem with my K20/4. It sent it to Eric for a CLA and it was oil on the blades. After the CLA all is well!
50mm f1.2, advice, aperture, blades, f1.2, k-mount, lens, pentax, pentax a 50mm, pentax lens, slr lens
Pentax M 50mm f1.7 aperture ring kbryant Pentax SLR Lens Discussion 1 03-25-2010 10:38 AM
Aperture problem with Pentax-A 50/1.7 D0ri Pentax SLR Lens Discussion 15 08-31-2009 09:51 AM
Problem with stuck aperture ring on Pentax KA 50mm f/1.7 jhaji Pentax SLR Lens Discussion 8 08-15-2009 04:10 PM
M 50mm F1.7 aperture problem atyab Pentax DSLR Discussion 4 03-28-2009 08:22 AM
SMC Pentax-M 50mm F1.7 - Aperture Display BlankGeneration Troubleshooting and Beginner Help 5 02-01-2009 08:56 AM
All times are GMT -7. The time now is 11:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
