10-12-2010, 11:05 AM   #1
Pentax-DA 50-200mm F4-5.6 ED WR and CIF
Hello everyone, can the Pentax-DA 50-200mm F4-5.6 ED WR be used with catch in focus? If it can. Where do I find the switch to turn off the auto focus?
Thank you
Jim
10-12-2010, 11:23 AM   #2
SpecialK's Avatar
The switch is normally on the side of the camera with AF-S(ingle), AF-C(ontinuous), and M(anual) choices.
10-12-2010, 11:59 AM   #3
Yes but there should be a way to turn off the autofocus on the lens also. I think. I have the DA *300 and there is a switch on the barrel of the lens that says AF and MF. But I don't see anything like this on this lens. I do know where the auto focus switch is on the camera body.
Thank you
Jim Browning
10-12-2010, 04:42 PM   #4
The 50-200 does not have it's own motor. Since it is powered by the screw drive in the camera the on camera switch is the the only way to turn off the auto focus.
10-12-2010, 09:09 PM   #5
Canada_Rockies's Avatar
QuoteOriginally posted by alwilliams Quote
And, unfortunately, that will also turn off catch-in-focus. With my K10, even trying to trick it by turning the lens to MF while leaving the camera set to AF-S (required for CIF) turns the AF in the camera off. No CIF with my DA* 50-135, darn it all. It works just fine with the M 100/4 macro and the M 400/5.6, but not with the 50-135.
10-12-2010, 10:46 PM   #6
pacerr's Avatar
Wasn't there a thread about this a while back regarding using a sticky foil strip to make the lens look like an M-mount without pins?
H2
10-13-2010, 12:47 AM   #7
axl
Doesn't K10 confirm focus with hexagon even in MF mode? I'll have a look into it.
Anyway, another trick is to depress the lens release button and the press AF. Since the screw driving the lens will be retracted it'll whirl without AFing the lens, but since the camera's AF sensor will be on it'll trip the shutter once you catch the focus...
10-13-2010, 08:14 AM   #8
QuoteOriginally posted by axl Quote
That's an interesting trick with the lens release Axl - I'll have to try it out once I figure out the way to do it without dropping my lens. The green hexagon does confirm focus even in manual mode, but when the camera is in MF, as you no doubt know, but other readers might not, Catch-in-focus is off. CIF only works when the camera mode is AF-S and the lens won't focus.
50-200mm, f4-5.6, focus, k-mount, pentax lens, pentax-da, pentax-da 50-200mm f4-5.6, slr lens, wr
Tamron 70-200mm f/2.8 vs. Sigma 70-200mm f/2.8 vs Pentax 50-135mm f/2.8 nah Pentax SLR Lens Discussion 27 12-08-2008 01:03 AM
For Sale - Sold: Pentax: 70-200mm AF and 80-200mm MF VPT Sold Items 1 05-26-2008 08:45 PM
All times are GMT -7. The time now is 07:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
