Originally posted by PGillin I need some help. I recently bought a Soligor Macro/Zoom lens (M42, FWIW), and it has a severely dented filter ring. This is a problem, because the front element threads in and out through the filter ring, and I need to clean the front element. I sprayed some lens cleaner on, and it got in behind the front element and formed a hell of a film. It's not supposed to, but it did.
Basically, if the filter ring has about a 1/2-1mm dent, can I do anything about it?
Also, if it is fixable, how do I get the front element out? I can tell the retaining ring just threads out, but what tool do I use to thread it out?
All advice is appreciated. Thanks.
You might try a toolmaker to get the dent out, hopefully it could be done without contact to the glass. The barrel may be slightly out of round from the contact that dent, which would explain why the cleaner could get beind the element so easily. Hopefully someone with a lens repair background will help you out. I tried to bend a dented filter ring once with no luck. I was afraid to put to much pressure on it and stress the barrel further down. I ended up just selling it as a damaged lens.
I hope you got it cheap, but good luck.
