Originally posted by wlachan Originally it was taped on using Nitto industrial strength tapes. If you see glue, it was a redo. A safe way of removing old adhesive is to rub them off with your thumb, then using duct tape to remove all remaining marks. It it was contact cement, then good luck.
Ahhhh...that's what it is...industrial strength tape. Makes perfect sense, now. I wasn't quite sure what to call it.
Looks like someone just touched up both peeling ends a bit to keep it from peeling further, so not a complete re-do. The rest of the barrel is clean. Fortunately what little touch-up adhesive is there comes off very easily.
I definitely want to use an adhesive that will bind, but will also be easily removable if it starts to peel back again. Hmmm...
