10-18-2010, 11:46 AM   #16
I have owned the Tamron for over 2 years now. Image quality is very good & af is responsive on the screw drive. I did have to adjust the focus in the menu on my GX20 to get it spot on.
Bad points... Build quality, the front bezel (Correct term??) that covers the front lens element is well known for coming loose. Mine regularly does which means removing the screw cover, having done mine a few times now the cover is difficult to refit.
Dust is also a problem, the lens is not very well sealed when compared to say the DA* range. I do however give mine a lot of hammer at the UK music festivals so maybe with care & attention an enthusiast user may not suffer the same issues.
Have a look in my flickr stream for examples. Most of the wide stuff is shot with that lens.
10-18-2010, 11:58 AM   #17
Pentaxor's Avatar
QuoteOriginally posted by woof Quote
I am not sure how the DA* compares with the Tamron, but the comparison is worth making with the DA 16-45mm.
Each has their negatives. DA16-45 has high CAs, though Pentax now corrects for that in their later bodies, and the Tamron has some serious field curvature. Overall the better MTF50 scores bleong clearly to the DA16-45mm. And in the second hand market it is significantly less expensive. The Tamron, if it is like my 28-75mm has a decent build quality. Some people do not like it. I personally think it is quite nice.
Frankly, the 16-45mm has won me so many ribbons at this point that I just never have really ever bothered to try the Tamron - initially I heard of a LOT of Q/A issues and the one I ALMOST bought was very, very soft. So it's been a bit of a non-starter.
With the addition of a DA 15mm for really serious work (turning red ribbons into blue ones), I am not sure I'll ever go there. The 16-45mm is simply a great walk-around wa to normal lens... and worth a look.
16-45mm
Pentax SMC-DA 16-45mm f/4 ED AL - Review / Test Report - Analysis
17-50mm
Tamron AF 17-50mm f/2.8 SP XR Di II LD Aspherical [IF] (Canon) - Review / Test Report - Analysis
I am certainly open to the suggestion that this is apples and oranges. Please don't pummel me. I'd prefer to just be enlightened.
woof!
well, let's just say that the Tamron 17-50 is the cheap and fast version of the Pentax DA* 16-50.
I'm sure the 16-45 is an excellent lens and only a tad lower than it's faster DA* counterpart. so in a way, the Tamron 17-50 bridge the gap between the two Pentax lenses. great IQ and speed performance at an affordable price.
10-18-2010, 12:00 PM   #18
Ed n Georgia's Avatar
I picked up a Tamron 17-50 f/2.8 a couple of months ago. It rarely leave my camera.
10-18-2010, 02:07 PM   #19
Great Picture
Cascade Pass, Adirondacks?
10-20-2010, 06:18 AM   #20
Jewelltrail's Avatar
stokas: Great Picture
Thank you for the complement! Yes, that is the location of the shot--you must know the area well.
10-20-2010, 08:52 AM   #21
My friend bought this Tamron for his Canon camera, I notice a 16-45 on the 2nd hand market, so enjoyed the read.
- Any real comparison shots?
10-31-2010, 08:30 PM   #22
Saxplayer1004's Avatar
I was playing with one of the Tamrons on a Nikon the other day. The focus ring was real weird in AF mode. When you went to adjust the ring it made a mechanical grinding. Was just a lack of disconnect between the AF motor and the focus ring. My first and currently only SDM is a 150-500 Sigma, which has a full disconnect between the motor and the ring which is nice. No grabbing at all. Something to think about. the photo quality was great, but the MF thing would bug me... Looking for a 16-50 now, the weather resistance is nice, especially for me being a professional scuba diver and doing a lot of highland game stuff. Rain won't make me worry
10-31-2010, 09:08 PM   #23
To manually focus this Tamron means switching camera body to MF first--takes a second. Like most lenses without a disconnect, you will do damage if you make it MF with the body in AF mode--OOOOOuch for you! However, I have so many MF lenses which were designed for the sole purpose of MF--they are a treat to throw the focus ring to and fro and need no quick shift gimmick.
This Tammy only does AF for me, which is what I bought it to do.
Btw, this Tamron needs no Weather Sealing, just common sense--see, for example: https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/120145-tamron-...x-16-50-a.html
11-01-2010, 02:57 AM   #24
Jasvox's Avatar
2 different animals, in my opinion. The 18-55WR is a neat little lens if you shoot outdoors and worry about/need a WR lens, but if you do not so much...the Tamron 17-50/2.8 is in a different league in terms of image quality and speed. When I bought my K-7 last year, the first thing I did was sell my 18-55WR since I already had the Tamron.
Jason
11-01-2010, 05:16 AM   #25
I've had the 18-55, 16-45 and the 17-50. Both the 16-45 and 17-50 make fine (and genuine) upgrades from the kit lens. I took some great pictures with the 16-45 and even now miss the extra mm over the tamron on the wide end. The 17-50 is my current normal zoom and I love it. Despite people niggling about the build quality I've found it to be excellent - anyone who has experienced the front element wobble of the 16-45 will recognise that the Tamron is pretty well put together. And f2.8 is the reason I got the lens - apart from the photographic opportunities, it also leads to a beautifully bright image in the viewfinder. And I love the images I get with it!
11-01-2010, 08:36 AM   #26
Cuchulainn: ......Anyone who has experienced the front element wobble of the 16-45 will recognise that the Tamron is pretty well put together.
It is not the "front element" which gets loose--it is the filter ring! I have not heard of one case of the glass coming loose on a 17-50mm, but I have heard of the filter ring loosening up.
I agree, the 17-50 is well built an so does Tamron, because they back it with a 6-year Warranty.
11-01-2010, 08:40 AM   #27
QuoteOriginally posted by Jewelltrail Quote
Read my post again - I'm talking about the 16-45, which does indeed show a wobble of 1-2mm on the whole front lens element. See here for a discussion of this elsewhere.
11-01-2010, 11:53 AM   #28
Cuchulainn: Read my post again - I'm talking about the 16-45, which does indeed show a wobble of 1-2mm on the whole front lens element.
Yes, you are correct! I read much too quickly and appreciate your correction. I see so many people mistaking the filter ring wobble of the Tammy 17-50 for the "front element" that I responded too quickly.
11-02-2010, 02:50 AM   #29
No problem! Hope my reply to you didn't come off too negative!
11-02-2010, 04:51 AM   #30
Jodokast96's Avatar
If AF/MF works anything like on the 70-200, just leave it switch to MF on the lens and switch it on the camera whenever you need it.
da18-55mm, f2.8, image, k-5, k-mount, kit, pentax lens, quality, slr lens, tamron, tamron 17-50mm f2.8, upgrade
Tamron 17-50mm .. is it REALLY worth it? Nightwings Pentax SLR Lens Discussion 36 08-17-2010 06:35 AM
The K 55mm 1:1.8 - worth having with the M 50mm 1:1.7? Jonathan Mac Pentax SLR Lens Discussion 21 06-01-2010 10:30 AM
DA*16-50 worth buying as replacement of DA18-55mm WR? Leo Miyanaga Pentax SLR Lens Discussion 17 10-10-2009 12:49 AM
Upgrade to Tamron 17-50mm from kit 18-55mm: worth the investment? virgilr Pentax SLR Lens Discussion 2 09-04-2009 07:33 AM
For Sale - Sold: K10d, DA18-55mm, DA50-200mm, Tamron 1.4x tc, DA10-17mm ssyli Sold Items 7 01-19-2009 05:05 PM
All times are GMT -7. The time now is 12:07 PM. | See also: NikonForums.com, part of our network of photo forums!
