Originally posted by fotaki Wow!! I think you've opened a can of worms here.
I have no technical based opinion on this but purely from the point of view of observing new lenses straight from the box, they all seem to arrive with the diaphram wide open. This would seem to suggest that lens manufacturers do have a preference.
Note, not all.
see my comment above, the FA-J and DA lenses do not have an option, the aperture si stopped down when not on a body, as is any A lens when dismounted in the A position.
Additionally In my Tamron instruction guide that came with my XR Di 28-75F2.8 there are no storage instructions, and with my sigma APO 70-200F2.8 EX ther eis the following
Basic care and storage
- avoid shocks and exposure to extreme high or low temperature or to humidity
- for extended storage, choose a cool and dry place, preferrably with good ventilation. To avoid damaging the lens coating keep away from mothballs or naphthalene gas.
- do not use thinner, benzene, or other organic cleaniong agents to remove dirt or fingerprints from the lens elements. Clean using a soft moistened cloth or tissue.
- this lens is not waterproof. When you use thelens in the rain or near water, keep it from getting wet. It is often impractical to repair the internalmechanism, lens elements, and electric components damaged by water
-sudden temperature change may cause condensation or fog to appearon the surface of the lens. When entering a warm room from the cold ourdoors, it is advisable to keep the lens in the case until the temperature of the lens approaches room temperature.
Seems crystal clear to me, they simply don't care about aperture.
Note also, while we are discussing pentax lenses here, many other makers have apertures that close automatically and open with the activation lever, canon and olympus come to mind immediately
