10-20-2010, 04:18 AM   #1
Tamron AF 18-250mm F/3.5-6.3 Di-II lens questions
Hi, I have just bought a K-x and figured that I need a Tamron AF 18-250mm F/3.5-6.3 Di-II.
I am confused with the different mounts. Can I buy Tamron AF 18-250mm F/3.5-6.3 Di-II for Nikon or Cannon?
By the way I have a Tamron p-k mount.
Please see the attached photos:
PENTAX K-x  Photo
PENTAX K-x  Photo
10-20-2010, 04:47 AM   #2
RioRico's Avatar
QuoteOriginally posted by henryzhang83 Quote
The adapter you show has no provision for autofocus (AF) or camera-lens linkage, i.e. no contacts. Pentax, Canon and Nikon AF mounts are all quite different and are NOT interchangeable. To use on your Kx, you need a Pentax-mount lens.
Generally, NO Canon lenses are usable on Pentax cameras. SOME Nikon lenses can be used, either modified or jammed-on, but without AF. By the way, I have the Pentax version of the 18-250 and it's my most-used lens when traveling with my K20D.
10-20-2010, 04:59 AM   #3
steve1307's Avatar
You can still get this lens in Canon or Nikon mount as new (279 USD)
Tamron 18-250mm f/3.5-6.3 Di-II LD Asph. IF Macro AF018NII-700 -
Tamron AF 18-250mm f/3.5-6.3 Di-II LD AF018C700 - B&H Photo
I guess there is some stock left as plenty of Canonikon users (including my father-in-law) go for the Tam 18-270 with VC instead.
The Pentax K-mount version i havent seen as new for a while.
It comes up in the used marketplace here or on fleabay occasionally selling for more than the new Canon or Nikon mount!! (300 - 350 ish?)
I might be heading off on a tangent here but, what are you thinking of doing? Taking the Kmount flange and then fitting it to a Canon or Nikon version?
I doubt this would work especially with the Nikon version which has a built in lens motor. Even if the flanges do fit you'd have no contacts for aperture reading and theres no aperture ring for manually stopping down.
I guess youd end up with a manual focus lens with fixed apaerture that wont focus at infinity because the registration distance of the 3 systems is different.
Most people get the 18-250 because it is a conveinent all around lens. Having it like that doesnt sound too convenient.
Edit: There's one in the marketplace here now. Asking price is 400 (getting rarer and harder to find evidently)
https://www.pentaxforums.com/forums/photographic-equipment-sale/118685-sale-p...-250mm-us.html
BTW the Pentax DA version is exactly the same, but suits lens correction functions in camera.
10-20-2010, 03:55 PM   #4
Thanks guys! Another lesson learnt
10-20-2010, 04:25 PM   #5
Laurentiu Cristofor's Avatar
The adapter looks like an adaptall adapter. It should come in handy if you ever get an adaptall lens, but it doesn't help with the 18-250.
10-20-2010, 11:49 PM   #6
hcc
hcc's Avatar
You already received some very good advice. You must buy a lens with K-mount (ie Pnetax mount).
Note that the Tamron 18-250mm is the sibbling of the Petnax DA18-250mm. Hence you can consider either: they are very close and both are very well respected in their class.
You may find the Tamron/Pentax 18-250mm at the marketplace (in this forum), in second hand respected retailers like www.keh.com and www.adorama.com, ebay and others. Try also your local stores. They may hav still a few. The Tamron/Pentax 18-250mm is discontinued, but the demand is still strong because the length is worth it.
The only other worthwhile alternative would be the newer Sigma 18-250mm OS HSM with K-mount. But it is dearer....
Hope that the comment will help.
18-250mm, af, af 18-250mm f/3.5-6.3, di-ii, f/3.5-6.3, k-mount, pentax lens, slr lens, tamron, tamron af 18-250mm
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
Questions about DA 18-250mm lens hood jpoint Pentax SLR Lens Discussion 3 06-12-2010 07:16 PM
Help with this Tamron 75-250mm lens? iht Troubleshooting and Beginner Help 2 08-03-2009 07:23 AM
For Sale - Sold: Tamron 18-250mm AF Lens Getting Old Sold Items 11 07-11-2009 10:24 AM
For Sale - Sold: Tamron AF 18-250mm 1:3.5-6.3 IF lens pcarfan Sold Items 3 02-07-2009 05:25 PM
All times are GMT -7. The time now is 10:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
