10-20-2010, 07:12 PM   #1
audiobomber's Avatar
Kiron 28mm f/2
I bought a Kiron Kino Precision 28mm f/2.0 in the Marketplace. I had some trouble at first. I can't seem to focus worth a damn, especially at f2. It overexposes on all my bodies when stopped down, but I don't think this is anything to do with the lens. It meters correctly wide open, so I meter at f2 and count the clicks. It has a slight blue cast, which is actually a good thing in Tungsten light, but sometimes needs correcting in daylight. It is almost as sharp as my FA 35, no mean feat. Contrast is excellent. Flare can be a problem, so I bought a rubber hood. I don't quite know what to make of the bokeh. At times it's classic, at times seems a little weird, but interesting nonetheless.
Here are a few samples, what do you think?
100% crop of above:
Last edited by audiobomber; 06-26-2011 at 06:11 AM. Reason: Corrected reference to FA 35
10-20-2010, 09:29 PM   #2
the bokeh look a bit harsh
you might want to use smaller aperture more often to get greater dof, e.g. in the 3rd picture
10-20-2010, 11:06 PM   #3
QuoteOriginally posted by audiobomber Quote
...I can't seem to AF worth a damn, especially at f2...
That might be because it is a manual focus lens. Even for manual focus with focus confirm, I think you may find that the DOF is sufficiently narrow wide open that the AF system will have problems. As for the exposure issues, I am assuming that your lens has no A setting on the aperture ring and should be used in M mode with the green button (stop-down metering). If you have a K-x or K-7 the camera should meter properly except in dim light with narrow apertures. With other bodies...YMMV.
10-21-2010, 12:06 AM   #4
axl
very busy OOF for my liking... but then again, I compare everything in this focal length against my 31ltd... tall order
As long as you are happy with it, it's fine...
10-21-2010, 04:18 AM   #5
QuoteOriginally posted by cerebrate Quote
The bokeh is nothing like any of my other lenses and I wasn't sure what to make of it. It does seem very busy.
I intentionally shot all these wide open to test the lens.
10-21-2010, 04:25 AM   #6
Sorry, it was a typo. I meant to say "focus", not AF. I'll change the OP so as not to confuse anyone else.
The lens is fully manual. If I use it in M mode wide open, or in Av mode where it doesnt' stop down, I get perfect exposure. If I stop down in M mode, it doesn't give me the correct exposure on the K20 or on the K-x. My Cosina A 28mm behaves similarly, on any of my cameras including the K-x; stopped down it overexposes. I'll have to do some more tests to figure out by how much.
10-21-2010, 04:43 AM   #7
I kind of like mine.. Don't use it much (because I have too many lenses).. When I got it I had to completely take it apart to clean the oil from the aperture. Fortunately I got it put back together right.
Couldn't state that this is wide open, in fact it probably isn't but it's fairly wide open (cropped photo).
Full Uncropped Image
10-21-2010, 04:55 AM   #8
QuoteOriginally posted by axl Quote
The lens has had a lot of praise on the net. I guess bokeh isn't their priority.
28mm, f2, k-mount, kiron, kiron 28mm, pentax lens, slr lens, times
First shot with 28mm Kiron - Florida Flower mediaslinky Post Your Photos! 0 03-13-2009 07:19 AM
My new old Kiron 28mm mediaslinky Pentax SLR Lens Discussion 0 03-09-2009 05:28 PM
Kiron 28mm f/2.8 platinum Pentax SLR Lens Discussion 1 06-09-2008 07:47 AM
Pictures using kiron 28mm f2 lens schmikey Post Your Photos! 6 07-22-2007 10:18 AM
All times are GMT -7. The time now is 08:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
