Originally posted by CEWren Anyone have any experience with a Sears Auto 80-200 1:4.0. this thing is throwing me for a loop. No matter what I do I cant get focus except in the (aprox) 4 to 10 ft range
I have tried with it in and out of macro setting... I figure it prob wont focus closer than 4 ft, that doesnt bother me... but the fact that I cant focus on anything more than 10 ft away does. I have tried and tried with this lens and I am about to give up on it. I like my 60-300 just fine.
Any help before I get rid of this bugger??
It's possible the front barrel has simply come loose or been maladjusted, throwing off the front group. One'd have to look at it to be sure. When you say 'In and out of macro setting,' this may also mean that there's a separate movement in there for closer-focus that simply isn't returning all the way to normal as well.
(A lot of things were called 'Macro' but four feet close focus for a lens of that type really wouldn't be very bad in those days. I've a little Kiron of that range which goes no closer. (surveying little collection of third-party zooms of that sort. Yep, they'd call closer than 4.5 feet 'Macro' on lenses like that routinely. (Marketing, that: not one of the photo industry's prouder moments, if you asked me) That much is likely is nothing broken.
) Not focusing at the long end probably simply means it's not getting there, though. It's possible to have this not work by a couple of means. The simplest being you may not be all the way out of any 'macro' setting if there is said separate movement. Next simplest being the lens was cleaned or twisted and not put back in alignment.
Can we see a photo of the lens? Sears put their brand name on a lot of things.
