06-26-2011, 10:12 PM   #61
The 40mm works well for outdoors shots:
06-26-2011, 10:52 PM   #62
Marc Sabatella's Avatar
The DA40 is essentially the M40 without aperture ring.
Just to clarify, it might have the same focal length and similar physical characteristics, but it's a different (superior) optical design, and also has about the fastest AF in the Pentax system.
Part of what I find attractive about 40mm on APS-C is that it helps one focus on just the heart of a scene, cutting out some of extraneous stuff. But not so much that it seems like much of a "telephoto".
06-27-2011, 06:39 AM   #63
paperbag846's Avatar
Interesting thoughts on the 40 -
I second Marc's sentiments on the isolation factor of the DA 40 on digital. It does not feel tele, but it's certainly more selective than a "normal" like 35mm, or more, 28mm.
It allows for a more selective composition, which can enhance your photography. IQ is pretty much perfect and AF speed means you will never miss a shot.
06-27-2011, 07:20 AM   #64
Blue's Avatar
To add to Marc's comments, the layout and formula are similar but the elements were re-designed for the DA and the rear element of the DA 40 has Ghostless Coating.
M 40/2.8
The re-designed elements of the DA 40/2.8
Compliments of Dimitrov.
06-27-2011, 03:11 PM   #65
RioRico's Avatar
Thanks for the clarification, guys. My point was that the 40 (whether M or DA) is by no means a tele design, yet on APS-C cameras it fills the role of what are called "short teles" on FF. So it's rather like using a Helios-44 on a Spotty, but twice as slow (for DOF equivalence). Oops, did I just open another can of worms? Nice, juicy worms...
06-27-2011, 04:45 PM   #66
I was just out with the kit using it at 40. It's a little tight for a "normal", but it's certainly not tele. I suppose it's at 50mm that things begin to feel tele.
06-27-2011, 04:46 PM   #67
Blue's Avatar
I agree with you there. Plus, I bet that when the development of the DA 40 started, Pentax was working on the MZ-D.
06-27-2011, 06:23 PM   #68
Clarkey's Avatar
Bite, bite.
I'm still stuck on the fact I can shoot through a chain link fence without interference.
Works really well on a micro 4/3 body too.
Would that be sacrilege?
06-27-2011, 07:53 PM   #69
Blue's Avatar
QuoteOriginally posted by Clarkey Quote
Bite, bite.
I have done that. How can you control the aperture? It does pretty good wide open.
06-28-2011, 08:13 PM   #70
Clarkey's Avatar
Courtesy of a fotodiox pk/m43 adapter (which was suggested courtesy of JohnmFlores). All of $30.
The stops aren't marked - its a slide on the adapter body over an internal screw that pokes out and activates the diaphram lever on the lens, but I found I can approximate F4.0 pretty well (compared with stop down aperture on the K-7), and as it is LV, can see the DOF in the monitor. Pretty cool, and a nice tele effect.
But sacrilege for sure.
06-28-2011, 08:20 PM   #71
Blue's Avatar
Holy flip, I forgot about that feature. BrownBag Woo hoo. I had used the A 50/1.2 and FA 77 on there so much since I got the Fotodiox, I totally forgot about that feature.
06-28-2011, 08:21 PM   #72
Clarkey's Avatar
Holy flip, I forgot about that feature. :BrownBag: Woo hoo.
Glad to make your day. Have fun.
09-26-2011, 06:21 PM   #73
DA 40mm
The DA 40 is AMAZING!!!!
I only have this and the kit lens but I have barely touched the 18-55 since I bought it!
Images are perfect perfect perfect, amazing sharpness, colours, no fringing.
A bit of vignetting at f2.8 but to be honest, I like it!
If the other Limiteds are this good, I think I might just buy all of them!
Some photos I have taken in the week I have had this lens:
Angel Up Above
White
Rainbow Bokeh
Choo Choo
Japanese Garden
I also found it perfect for panoramas! Thanks for viewing!
09-26-2011, 06:44 PM   #74
twitch's Avatar
QuoteOriginally posted by BendingPhotography Quote
Nice pics.... but I have bad news for you, not only are the other limiteds as good, a few are even better....
From the limiteds I have I think the IQ pecking order goes DA21 < DA40 = DA15 < DA70 = FA77 < FA31.
09-26-2011, 06:48 PM   #75
Clarkey's Avatar
QuoteOriginally posted by twitch Quote
you forgot the 35 Macro....
40mm, da, da 40mm, k-mount, lens, pentax lens, slr lens
DA 40mm f2.8 wed7 Pentax SLR Lens Discussion 7 05-02-2010 03:54 AM
which 40mm? pentax da 40 or Voigtlander Ultron 40mm f/2.0 SL-II dexmus Pentax SLR Lens Discussion 12 10-30-2009 07:26 PM
DA 40mm ltd blotzphoto Pentax SLR Lens Discussion 21 03-05-2009 07:31 PM
All times are GMT -7. The time now is 05:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
