10-24-2010, 05:51 AM   #1
Pentax Da 16-45 or D200 fault
I just picked up a used Da 16-45. I had it out taking picks of couple buildings but the lens had a hard time focusing .I had to aim it at 4-6 spots on the building just to get a lock to take the pic. The Sky was full of dark clouds with a bit of light coming through ( hard to adjust lighting because of the white blow outs in the clouds when bringing up lighting on the buildings on computer). Just wondering is this due to the camera or the lens? Brought the kit home shot around the house no probs with focusing using just the lighting in the house. Iím thinking to mono-chrome and couldn't get a lock. Any thoughts. I ended up with a lot of PP work and then made it into a HDR just to get it to look good.
10-24-2010, 06:43 AM   #2
pacerr's Avatar
It would take a lot more specific info about your camera and menu settings to help you with this. If you got accurate focus in any given circumstances it's not likely that the camera or lens is at fault though. I presume you meant the K200D here. The DA 16-45 is normally a very reliable lens.
Your first step is to compare the focus options and settings in the manual with your own conditions and experiment with the lens in controlled conditions.
How did it fare in manual focus mode?
H2
10-24-2010, 06:49 PM   #3
SpecialK's Avatar
Plain subject with little contrast?
10-24-2010, 07:31 PM   #4
QuoteOriginally posted by djayvo Quote
I've had some problems with mine at 16mm when trying to focus on low-contrast infinity subjects. If this is the same as what you were experiencing, you can try zooming in to lock focus and then zoom back out to take the shot. But you might also need to pay attention to your exposure readings (or lock the exposure separately using the AE-L button).
10-25-2010, 07:27 PM   #5
Thank you
From what I hear this lens is a good performer.
I find it funny that my 18-250 I have never had this problem.
I know every lens has a learning curve. Just found it funny that it focused on everything in the house with just couple lights on. It was a very dull day as far as the lighting goes every pic lacked that wow factor. Iíll try that zoom focus zoom next time and also the AE-L change.
Thanks
buildings, clouds, da, house, k-mount, lens, lock, pentax da, pentax lens, slr lens
Pentax K110D shutter release button fault? bogner Pentax DSLR Discussion 0 12-23-2009 09:09 AM
Pentax K10 D Fault. Images are Green. Please Help. 1cut808 Pentax DSLR Discussion 4 12-21-2009 05:46 PM
Pentax K10D vs Nikon D200 karq Pentax DSLR Discussion 14 02-01-2009 03:34 AM
D200 Or K20 Cvrn Pentax DSLR Discussion 19 02-25-2008 11:22 PM
Nikon D200 vs Pentax K10D codiac2600 Pentax DSLR Discussion 5 05-03-2007 08:47 AM
All times are GMT -7. The time now is 04:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
