Altopiet, I'm not sure you have a particularly bad 18-55 here (but your 50-200 seems to be one of the good ones - hang onto it!), the kit lens isn't meant to be all that good at the wide end, for instance. Take a look here for some measurements made on the 18-55 (and 16-45):
To Kit or not to Kit ? Three Pentax Kit Lenses ERPhotoReview
(This is the umpteenth time I've posted this link, so apologies if you've already been there - on the other hand, if you haven't seen it, I think it's quite revealing and informative.)
You'll note that the DA 16-45 gets a favourable review here, and that lens would be on my shopping list as a replacement for my kit lens (if I could justify the expense, which I can't, at the moment). On the negative side, it is a bit bulky, of course.
Richardm - my heart goes out to you, you seem to have ended up with one of the worst DA 50-200s out there. My impression of this lens is that ALL copies are different (mine's good at the long end, it didn't cost much, and it's nice and compact, so I don't mind the fact that I don't use it at the wide end). I hope you can get a replacement under warranty - good luck!
