10-28-2010, 02:33 PM   #16
axl
QuoteOriginally posted by omega leader Quote
Alright here goes...The depth of field is the same.
A 35mm lens at f1.4, and 55mm lens at f1.4 and an 85mm lens at f1.4 all have the same absolute depth of field if you are framing the same subject on the same format (i.e. a headshot with an APS-C camera).
The only thing that will change will be the amount of background visible. So decide if you like the look of a 85mm lens or the look of a 55mm lens. You can decide this from using a zoom and looking carefully at the background.
this is only true if you don't change the subject - medium distance. Since you are using different FLs trying to achieve the same framing, your distance will change and so will your DOF
10-29-2010, 02:21 PM   #17
summonbaka's Avatar
Try your DA70 for the photo you want, the max aperture of f/2.3 is something to take into account. Also, the A50/1.2 could be a different alternative to the shot.
55mm, da, da*, experience, f1.4, fa, k-mount, pentax lens, photo, slr lens
REVIEW: Samyang 85mm F1.4 Aspherical IF tranq78 Pentax SLR Lens Discussion 159 01-08-2012 06:20 AM
Misc A couple of weeks with Samyang 85mm f1.4 brkl Post Your Photos! 4 07-04-2010 09:38 AM
Portrait with new Samyang 85mm f1.4 James S Post Your Photos! 4 04-20-2009 03:23 PM
Samyang 85mm f1.4? mikengstrom Pentax SLR Lens Discussion 56 01-10-2009 05:51 PM
All times are GMT -7. The time now is 08:40 PM. | See also: NikonForums.com, part of our network of photo forums!
