10-26-2010, 09:53 PM   #16
Pentaxor's Avatar
QuoteOriginally posted by paperbag846 Quote
If neither will pull that off though, I'll buy the 35 for less and save up for the DA 70 .
this would be a better idea.
10-26-2010, 09:54 PM   #17
paperbag846's Avatar
What I have and like on the wide side are the Zenitar 16/2.8 (the least cheap); Tokina-made M42 21/3.8 and 24/2.8 and PK 35/2.8; Tamron PK 28/2.5; If I can get my Vivitar-Komine 24/2 fixed or replaced, it might stand in for the 21 and 28. A 35/2 or faster would be nice too, a stand-in for a FF Nifty Fifty.
Great suggestions. In many cases, I am happy with the feel of manual focus.
However I see this "normal" focal length as being my go-to for people - moving, maybe not ideal light, so AF and reasonable speed are important for this purchase. However, I do not feel the need to replace all my lenses with AF, and I will certainly keep my eye out for the Vivitar-Komine .
EDIT: So just to clarify, Pentaxor, is smooth bokeh really only going to be found in the 50mm+ lenses? I've noticed, for example, that my 55mm renders OOF areas MUCH nicer than my 50mm... which I found slightly odd at first since they are so similar in the focal length sense.
10-26-2010, 10:05 PM   #18
Pentaxor's Avatar
it's also dependent on aperture speed and optical formula aside from focal length. focal length is just one area that influences DOF as far as calculations go. smoothness depends on optical formula as far as corrections are concerned. it just so happened that most if not all 50mm lens display a smooth bokeh. of course, not every 50mm lens is consistently smooth but some are. of course, there are some wide lenses that are exceptions and could do smooth bokeh as well. Sigma 30 and FA31. I find the old K28/2 smooth as well.
28mm, da, k-mount, kit, pentax lens, slr lens, thread
K-7 Kit recommendations SkagitFly Pentax DSLR Discussion 17 10-04-2010 04:36 AM
Recommendations for replacing the 18-55mm DA-L Kit Lens... Internetpilot Pentax SLR Lens Discussion 66 06-12-2010 11:49 PM
Looking to replace my K-x kit lenses - recommendations please iankh Pentax SLR Lens Discussion 21 04-26-2010 09:26 AM
Need recommendations on my kit (75/25 portrait/landscape) krypticide Pentax SLR Lens Discussion 10 11-15-2008 04:36 PM
Prime Recommendations Between 24 and 50 ? daacon Pentax SLR Lens Discussion 30 04-07-2008 01:07 PM
All times are GMT -7. The time now is 11:44 PM. | See also: NikonForums.com, part of our network of photo forums!
