Originally posted by Pentaxor look for the K55/1.8.
I second this - it has very nice bokeh.
The 55 1.8 paired with a 28 2.8 will give you a nice range with good quality. The 55 for low light / low DOF and the 28 2.8 for a slightly wider than normal field of view.
If you are ok with stop-down metering you should be able to buy both for 100 dollars ish.
However, if I understand you correctly it is ease-of use you are looking for, for "off the cuff" shots, where setting up the helios is just too slow?
Another option would be the new DA 35 2.4, which should not be over 200 dollars. It's relatively fast, look quite nice, and autofocus. It is a very flexible field of view, and would pair nicely with your fast manual for portraits.
