09-17-2007, 08:43 AM   #1
Tom M's Avatar
What's the difference between these lenses? (Sigma)
I'm looking at these lenses, both are in stock brand new and I can't figure out what the difference is..
Sigma 170-500mm f/5-6.3 APO
and..
Sigma 170-500mm f/5-6.3 APO DG
The DG version is actually $10 cheaper but the descriptions are identical.
My point is, if the DG is a Designed for Digital lens, why are the descriptions identical? The coatings don't mention anything different.
Thanks in advance.
09-17-2007, 08:55 AM   #2
m8o
m8o's Avatar
DG if I remember correctly is an anti-reflective coating. Digital SLRs are suceptable to internal reflections within the body due to reflection off the highly reflective image sensor.
DG is meant to reduce secondary reflections back onto the sensor from light that reflected off of the sensor onto the inner lenses, then back onto the sensor.
Hope I'm not making things up. Anyone else, please confirm or correct.
09-17-2007, 01:08 PM   #3
I think DG is for digital APS-C format sensors (not full frame). Here is a description from Sigma's site. Sigma - Lenses - Overview
09-17-2007, 01:17 PM   #4
QuoteOriginally posted by eman Quote
I don't think that DG is for APS-C formats specifically. DC would be for that format. DG is digial multicoating and generally means that the lens can be used with film cameras too.
Stephen
09-17-2007, 02:41 PM   #5
Correct. The non DG version is actually an older lens. DG just means it is optimized for digital cameras with a lens coating as mentioned above.
09-17-2007, 03:38 PM   #6
QuoteOriginally posted by Tom M Quote
and..
Thanks in advance.
The difference is that the non-DG APO is "brand new" as in "sitting on the shelf unsold for a few years", while the DG has modern coatings.
09-17-2007, 05:31 PM   #7
Arpe's Avatar
Yep, DG=coating for digital, DC=for digital only (APS-C sensors)
170-500mm, apo, descriptions, dg, f/5-6.3, k-mount, lenses, pentax lens, sigma, slr lens
What is the difference between these two 55-300mm lenses? RUSBoris Pentax DSLR Discussion 6 10-11-2010 07:49 PM
What's the difference between K and M lenses? ismaelg Pentax SLR Lens Discussion 17 02-02-2010 02:48 PM
What is the difference bwt WR and DA* lenses? rdrum76 Pentax SLR Lens Discussion 5 07-16-2009 10:43 AM
Difference between F and FA lenses?? mr tibbs Troubleshooting and Beginner Help 4 04-17-2009 09:50 AM
Difference between 50mm lenses Tammmzy Pentax SLR Lens Discussion 5 02-28-2009 06:51 PM
All times are GMT -7. The time now is 04:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
