hi - back to this again......
having given a bit more thought i think the k-7 photo above was a bit unfair - when i rechecked the shutter speed was only 1/10 of a second - so its not really a fair shot.
So what next....i thought i would compare using a flash so as to even up the field a bit and i thought i would compare the 28-300 (the one i was complaining about) and my 70-210 (sigma also).
here are the two shots.
and
ok first thing is if you lookt it is clear that one shot is sharper than the other.....also it is clear from these two shots taken from the exact same postion that the focal length of one is greater than the other.
Ok here is the real kicker - the shot where the DVD box is larger is the 70-210mm NOT The 28-300 (both used wide open at max zoom)
WHAT THE??? does this make any sense at all
