11-01-2010, 01:39 PM   #1
18-200+mm lens recommendations
I'm looking to upgrade my starter lenses with a single zoom lens. I've seen several and I was wondering if there is a particular one that stands out against the rest.
These are the lenses I'm currently considering:
Sigma 18-200mm f/3.5-6.3 DC Aspherical (IF) Lens
Sigma 18-250mm f/3.5-6.3 DC OS HSM Autofocus Zoom Lens
Pentax SMC DA 18-135mm F/3.5-5.6 ED AL (IF) DC WR Lens
Tamron Zoom 18-200mm f/3.5-6.3 XR Di-II LD Aspherical (IF) Macro Lens
I'd be replacing a Tamron 28-105mm AF f/4-5.6, a Tamron 80-210mm AF f/4.5-5.6, and a Sigma 70-150 f/3.5 MF. I generally use the 28-105 the most as it covers a good range, but I find myself wishing it was wider and had longer reach. I have around $500.
Thanks
11-01-2010, 01:42 PM   #2
Senior Moderator
Parallax's Avatar
I have the Sigma 18-250mm f/3.5-6.3 DC OS HSM. The IQ is better than I ever expected for a super tele and seeing a stabilized image in the viewfinder is a real plus.
11-01-2010, 01:53 PM   #3
Lowell Goudge's Avatar
I think the pentax 18-135 would probably be the best performer.
I am always somewhat skeptical about 10:1 zooms and Image quality over the entire range.
A more conservative zoom range should be a better bet.
Aside from that observation, I think you would then be well placed to add an ultra wide at the short end, and have everything basically covered.
Longer lengths would be specific to sports/wild life and you have different optipns when the middle lens covers up to 135mm
11-02-2010, 03:57 PM   #4
I've used the Tamron and it is good...for his price.
The better one is probably the Pentax 18-135 as Lowell Goudge said (and it's WR too).
11-02-2010, 04:44 PM   #5
jimr-pdx's Avatar
Back in my A200 days I owned Tamron's 18-250 and Sigma's 18-200 (quantaray label, via Ritz Camera closeout). Both did quite well on 10mpx sensor; I preferred the compactness of 18-200 and sold the Tamron. As Lowell noted though, the chance of excellence at all focal lengths is elusive; both my lenses fared poorly around 100mm in my crude tests. When I went to K-7 I decided not to press my luck with the extra 4 megapixels, having heard many times that denser sensors demand good glass. Now I dare not try one to learn I'm wrong!
I'm quite pleased with 16-45 and 55-300 combo, but am watching with interest for the 18-135. With its weather resistance and Pentax pedigree I'm thinking it would be worthwhile.
11-02-2010, 06:43 PM   #6
hcc
hcc's Avatar
You already received some good advice. Let me add a bit of 'spice'.
First I would expand your list:
Pentax-DA 18-250mm F3.5-6.3 ED AL [IF]
Tamron AF 18-250mm F/3.5-6.3 Di II LD
The DA18-250mm and Tamron 18-250mm were both manufactured by Tamron. The lenses are highly regarded as among the best all-around zoom lenses. Although the production stopped, they can be found 2nd hand: marketplace, specialised 2nd hand shop like Keh, ...
Second, your choice must be linked with your needs. If you need a WR lens, the newer 18-135mm WR is the one to choose.
The Sigma 18-250mm OS HSM received some good users' comments in a number of threads of this forum. It is slightly dear, and the OS is redundant with your camera IS.
The Pentax/Tamron 18-250mm is regarded as a better lens than the older Tamron 18-200 and Sigma 18-200 lenses. If you can get a Tamron/Pentax 18-250 on the market place at a reasonable price, I would recommend it very strongly.
Hope that the comment may assist....
11-03-2010, 05:18 AM   #7
Senior Moderator
Parallax's Avatar
The only part of the above I would argue is the part about the Sigma IS being redundant. The stabilized image in the viewfinder I find aids composition at longer FLs, and I read, but not tested, that it also aids auto-focus.
af, dc, f/3.5-6.3, k-mount, lens, lenses, mm lens, pentax lens, sigma, slr lens, tamron
Lens recommendations laura Pentax SLR Lens Discussion 17 06-29-2010 07:44 PM
Looking for some lens recommendations Grunf911 Pentax SLR Lens Discussion 8 01-03-2010 11:47 AM
New lens recommendations? Ecosse Pentax SLR Lens Discussion 22 04-09-2008 04:28 PM
50-200 replacement - any recommendations ? simonkit Pentax SLR Lens Discussion 13 09-02-2007 08:23 AM
Recommendations in 50-200 zoom range Arpe Pentax SLR Lens Discussion 10 09-11-2006 05:11 PM
All times are GMT -7. The time now is 07:26 PM. | See also: NikonForums.com, part of our network of photo forums!
