11-03-2010, 01:36 PM   #1
K55mm f1.8 vs SMC Super Tak 55mm f1.8
Basically, I'm asking what's the real difference (other than Mount type)? Can somebody who has or has had both, shed some light on one vs the other? I'm asking because I'm interested in the K55 (have the M42 55) but would like to hear real world feedback on the difference.
11-03-2010, 01:46 PM   #2
dgaies's Avatar
I've never used a Tak, but if you're really curious and want to spend $5 on shipping each way, you can borrow mine for as long as you need.
11-03-2010, 02:09 PM   #3
axl
I believe there isn't any difference.
The K55/1.8 is the same optics and I believe the same SMC as SMC Tak. The outer shell is different and that's it IMHO....
This is not based on experience though but on web searches....
11-03-2010, 02:44 PM   #4
The latest version of the lens is literally identical except for the grip and mount: SMC/S-M-C/Super-/Auto-/Takumar 55mm F1.8 Lens Reviews - Pentax Lens Review Database
11-03-2010, 09:44 PM - 1 Like   #5
gofour3's Avatar
The SMC coatings were improved when the K Series was releasd in 1975. The K55/1.8 also has a minimum aperature of f/22 the SMC Tak was f/16. The filter size is also different, 52mm to 49mm.
Phil.
11-03-2010, 10:08 PM   #6
QuoteOriginally posted by gofour3 Quote
Phil.
I am pretty sure that the larger 52 mm filter size is matched by a somewhat larger diameter lens body in general. I own the K 55/1.8 and have handled the SMC 55/1.8 and that was my impression anyway.
11-04-2010, 05:23 PM   #7
gofour3's Avatar
Yes for sure, the K55/1.8 has a diameter of 63mm and the Tak55/1.8 is 57.7mm.
The K55/1.8 is also 1mm longer at 39mm.
Phil.
11-04-2010, 06:48 PM   #8
I think one difference is how it would behave on the camera, metering. The K mount you would use the green button, for the SMC tak you'd probably use A and preset the lens to aperture you want, it would meter itself.
Also, the taks seems just a bit smoother for focusing, though the K is also very nice to use.
Also, if it's the Super Takumar the coatings are not quite as good as the SMC or K, so double check if it's super takumar or SMC.
11-04-2010, 07:57 PM   #9
dgaies's Avatar
QuoteOriginally posted by dgaies Quote
K55/1.8 en route
11-04-2010, 09:11 PM   #10
QuoteOriginally posted by kathyk Quote
Actually, I barely ever touch the green button. For K/M type lenses, I activate the Optical Preview which activates the meter in the viewfinder and stops the lens down. From there I dial in the exposure I want.
11-05-2010, 09:06 AM   #11
QuoteOriginally posted by JeffJS Quote
Sounds interesting, I have to confess I'm not familiar with that procedure.
11-05-2010, 09:19 AM   #12
paperbag846's Avatar
If this is what you do, the K55 will only be nice because it will remove the need for an adapter. The lenses are supposed to be optically identical.
11-05-2010, 09:33 AM   #13
I do it this way because the Green button just centers the exposure, just like the auto modes do for A type lenses. The result is, something is always too dark, or too bright. I know there is exposure compensation for those times but I still prefer when going manual, to adjust the meter where I want it to be.
QuoteOriginally posted by paperbag846 Quote
Never been a fan of using adapters. The M42 lenses also won't do stop down metering and I like having the lens wide open for focusing purposes. I know there are ways to use all lenses in any fashion desired but I've just grown to like the K/M lenses for manual shooting.
Another forum member who posted here has been kind enough to offer his copy for evaluation. I'm looking forward to doing a side by side on these two lenses and deciding if it's worth replacing the M42 with the K.
11-05-2010, 09:36 AM   #14
Good luck with your evaluation! At the prices these lenses go for, I think it would be worthwhile switching to the K 55 for the functionality (personal opinion!) I doubt there would be any good reason to own both.
11-05-2010, 02:48 PM   #15
Could you please tell how you do that and in which mode? Is it possible with M42 lenses to?
f1.8, k-mount, pentax lens, slr lens, tak 55mm, vs
Super Tak f2 55mm Garyleed Pentax SLR Lens Discussion 3 12-01-2009 06:12 PM
For Sale - Sold: SMC Tak 150mm/4, SMC Tak 135mm/3.5, Super Tak 55mm/2 and extras pdxbmw Sold Items 8 09-10-2009 10:54 AM
Super Tak 55mm k mount conversion help needed Steve Beswick Pentax SLR Lens Discussion 16 09-01-2009 06:21 AM
All times are GMT -7. The time now is 06:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
