11-03-2010, 06:36 PM   #1
eccs19's Avatar
Sigma 105mm Macro questions
Couple of questions regarding this lens.
1. It's got a manual / automatic focus ring to switch between modes. I've noticed that even if it's in manual mode, if the camera is still in auto focus, the camera still focuses the lens. I assume it's more just for disabling the motor so you won't burn it out trying to reef on it?
2. I'm sure this is more camera related, not lens, but if I'm using the lens NOT in A mode (for the aperture), how do I get the camera to meter? (AV mode) On my *istD, I was sure I would use the green button, but doesn't seem to do this on my K7. Or does it only do it in manual mode, and I'm mistaken how it worked on my *istD?
11-03-2010, 06:48 PM   #2
QuoteOriginally posted by eccs19 Quote
Don't have the particular lens, these is only my guess:
The manual/automatic focus ring doesn't really turn the lens into "manual" focus mode. Rather, when at "auto" setting, it disengages the focus ring from the focusing mechanism inside the lens so when the body focuses the lens, the ring does not rotate. At "manual" setting, the ring rotates when the body focuses the lens.
Of course if you really want to focus manually, you have to (1) set to MF on the body and (2) switch the lens to "manual" so you can focus the lens using the focus ring.
I don't think there is a motor inside the lens.
In Av mode and with the lens not at A aperture setting, the K7 takes the photo at full aperture. If you want to meter using the green button, you have to switch the K7 body to M. This is the same with K10D, K20D (and probably all current Pentax bodies).
11-04-2010, 05:34 AM   #3
eccs19's Avatar
Thanks for the info. Sounds like you confirmed what I was thinking.
*istd, camera, focus, k-mount, lens, mode, pentax lens, questions, sigma 105mm macro, slr lens
Sigma 105mm Macro EX vs EX DG??? Mr Hyde Pentax SLR Lens Discussion 7 07-15-2014 07:51 AM
Wanted - Acquired: Tamron 90mm Macro or Sigma 105mm Macro (AUS) Pixley Sold Items 2 09-28-2010 08:32 PM
For Sale - Sold: Sigma 17-70mm, Sigma 10-20mm, Vivitar S1 105mm 2.5 Macro 1:1 jjdgti Sold Items 17 08-02-2010 11:05 AM
Questions on Sigma 105mm f/2.8 1:1 Macro Ex (non-DG) hinman Pentax SLR Lens Discussion 10 10-14-2008 06:03 PM
Sigma 105mm f/2.8 Macro vs smcP-D FA 100mm f/2.8 Macro Trub Pentax SLR Lens Discussion 4 04-20-2007 11:58 PM
All times are GMT -7. The time now is 11:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
