11-07-2010, 12:15 PM   #1
Pablom's Avatar
New K 1.8/55. Do I have a problem?
Hey guys, I just got myself a SMC Pentax 1.8/55 from a certain auction site.
It looks plenty nice and sharp from the first few shots I took with it but there is one problem, when I turn the focusing ring I can feel and hear a sound of what I can only describe as grease and dust smearing.
Everything else seems fine, the iris seems to work flawlessly at every stop and it meters just about as any other manual lens I tried, but this thing with the focusing ring bothers me a little, it also seems like it causes the focusing ring not to turn as smoothly as it should, though it does pretty well for me and I don't really know how it is suposed to be since I never used a K series lens before.
Well, I would like to know what is this thing I am describing and if it can have any effect on the lens' usability (currently or in the future), so I would like to hear from anyone who had a similar experience or maybe knows a way to fix this, if it does require fixing.
Thanks,
Pablo
11-07-2010, 12:41 PM   #2
Ira
Rotate the focusing ring back and forth as fast as you can for like a full minute.
If it isn't affecting the images, you can learn to live with it, as annoying as it might be.
But what I suggest is the same fix used for audio electronics knobs that get dirty. You're simply grinding down and loosening those particles.
11-07-2010, 12:47 PM   #3
After you start using the lens, the ring should loosen up to normal levels. The same thing happened to be when I bought my first 35-105mm- the lens could barely zoom at first, and there was a similar noise. After I had been using it for about a month, everything seemed normal, and the zoom ring was smooth and noise-free.
11-07-2010, 01:04 PM   #4
Pablom's Avatar
Thanks for the advice. I tried it and it did help a little with the sand-like feeling but the main thing that bothers me is the grease or whatever lubricant is there.
I'm not really thinking about a real disassemble of the lens since I will probably ruin things more than I can fix and sending it to a pro is not realistic considering the modest price I payed for the lens.
I guess I want a miracle solution if there is any, or maybe I'll just use it as it is and forget about the so called defect just like I handled the dust in my viewfinder.
11-07-2010, 01:05 PM   #5
Pablom's Avatar
thanks Adam, that is a relief, I hope I will have a similar experience
k-mount, lens, pentax lens, slr lens
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
Problem with K7 sammie Pentax DSLR Discussion 4 05-09-2010 09:28 PM
NEW and PROBLEM samgrom Welcomes and Introductions 6 03-06-2010 05:20 AM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
Do you have a problem... Alvin Pentax DSLR Discussion 15 03-03-2007 01:17 AM
All times are GMT -7. The time now is 11:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
